1983 550 Spectre - Carb vacuum line ?
- NDSpectre
29 Apr 2017 12:00
Here is a picture of my carbs with the vacuum lines attached. Carbs 1 and 4 are linked together by a T fitting that attaches to the vacuum switch valve. Carb 2 vacuum line goes to the petcock. Carb 3 vacuum fitting is capped. Any problem with that arrangement? Also, if I get rid of the vacuum switch valve, can I just cap Carbs 1 & 4 as well??
Re: 1983 550 Spectre - Carb vacuum line ?
29 Apr 2017 12:37
Yes
29 Apr 2017 12:59
Carbs are numbered left to right. Looks like petcock vacuum is coming off #3 and #2 is capped.
- NDSpectre
29 Apr 2017 15:03
Agreed the numbering is reversed in my post as the photo is of the side connected to the engine. Question - can you get rid of all the vacuum lines other than the one connected to the petcock - and does it matter which carb vacuum line is connected to the petcock?
- loudhvx
29 Apr 2017 17:01As Texas KZ said, "yes", you can get rid of those two vacuum line and cap them off.NDSpectre wrote: Agreed the numbering is reversed in my post as the photo is of the side connected to the engine. Question - can you get rid of all the vacuum lines other than the one connected to the petcock - and does it matter which carb vacuum line is connected to the petcock?
It does not matter which cylinder controls the petcock.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: NDSpectre
