kz1000 + bs34 cv carbs/pods clarification.
17 Jan 2011 22:06 #423185 by otakar
Replied by otakar on topic kz1000 + bs34 cv carbs/pods clarification.
notaduc wrote:
I was looking at the same set, are the all black stock? Or di someone rattlecan those?
The GPz750 had stock black Mikuni carburetors. The other 750s had silver Keihin carbs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • wagonmaster69
  • 78 KZ1000A2 / 82 KZ1100 Spectre
17 Jan 2011 22:35 #423188 by wagonmaster69
Replied by wagonmaster69 on topic kz1000 + bs34 cv carbs/pods clarification.
Ware are you from?
I have a set off a 1982 KZ1100 Spectre maybe we can work something out.
Cause I would like to rebuild the set I have on my bike and go with pods also.
18 Jan 2011 09:14 #423270 by notaduc
Replied by notaduc on topic kz1000 + bs34 cv carbs/pods clarification.
Will be running custom header/exhaust, pods, he did mention he had a three angle valve job when the head was overhauled.
1980 (mostly) KZ1000
18 Jan 2011 10:27 #423280 by otakar
Those mods still qualify as a stock application. On that engine the GPz750 setup will be the best.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
18 Jan 2011 13:54 #423317 by notaduc
Thanks again, should I plan to have to re-jet at all?
21 Jan 2011 17:51 #424209 by notaduc
keith1 wrote:
gs 1100 head is like apples to oranges.....kawi police carbs? what size?
If by apples to oranges, you mean spacing, I measured a set of gs1100 carbs, they are 75-95-75, I believe is the same as the kz1000.
If not, what did you mean?
21 Jan 2011 18:44 #424217 by notaduc
Hey, what makes the Keihin carbs junk?
Curious, trying to learn...
Thanks
21 Jan 2011 19:17 #424218 by hoghaterkaw
Replied by hoghaterkaw on topic kz1000 + bs34 cv carbs/pods clarification.
Thanks
Well the Keihin's arn't junk. That said, they are okay as a stock carb on a stock motor. The Keihin has two butterfly valves. The first is the choke plate at the air cleaner end then down stream of the slide there is the throttle plate. The Mikuni has only one butterfly plate, the throttle plate down stream of the slide. So the Keihin's 34's don' flow as well as Mikuni BS 34's giving the Mikuni a better flow rate for a given size.
