Good season start
  • turboguzzi
  • turboguzzi's Avatar Topic Author
Good season start
16 Apr 2015 08:22
#668193
so then, am i still the only member road racing a kawi here?
whatever, the italian vintage championship started last weekend at the Varano track and I brought home a 3rd place trophy on my old & trusty Gpz750/810 behind a full 1000 cc guzzi and duc.
amazingly, motor it still super strong after 4 seasons without much attention, was easily able to stay with a 16 valve, air-oil 750GSXR on the straights in one of the mixed classes practice, so that 90 rwhp was no fluke :)
cheers,
(i'm the told guy on the right BTW...)
TG
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
Re: Good season start
16 Apr 2015 09:16
#668204
Congrats! and thanks for putting a face to an avatar. Some of us do follow you in your posts on KZR.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • zukdave
  • zukdave's Avatar
16 Apr 2015 17:11
#668261
TG I may not comment but I do follow your post's about your racing.
Keep adding to this thread like I've done my drag strip thread
and keep it in one place will make it easyer to follow you.
As for racing road or drag very few on here race their KZ's
I guess their too scared of breaking them.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • mopguy
  • mopguy's Avatar
16 Apr 2015 17:18 - 16 Apr 2015 17:20
#668265
Auguri!! e Grazie assai per la vostra contribuzione al KZ Rider, da Toronto, Canada.
Last edit: 16 Apr 2015 17:20 by mopguy. Reason: added
  • bluezbike
  • bluezbike's Avatar
16 Apr 2015 23:31
#668324
Sweet start TG......I have never raced but may try one of these days......I follow your and zukdave's exploits, lots of luck to you both.
79 KZ 1000 LTD
  • turboguzzi
17 Apr 2015 14:42
#668430
tnxs guys
a side note, just for peace of mind took off this week the sump coveroff after four years to have a peek and it's amazing. not even a hit of swarf or metal particles, and i do plenty of clutchless shifting during a race. everything looks just perfect after 4 season of hard racing and shifting at 11K. Neither did the shims require any adjustment and that's with pretty hot cams. I do change oil and filter every other race though.
Dont know the bigger K motors that well , but i am tempted to say that the 650/750 unit is even more bullet proof!
  • zukdave
  • zukdave's Avatar
18 Apr 2015 12:22
#668552
I think the small four is a better motor with the one piece crank,
plain bearing's, a better oiling system and shim under bucket.
I beat the dog shit out of mine and don't worry about it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • loudhvx
  • loudhvx's Avatar
18 Apr 2015 13:16
#668563
zukdave wrote: I think the small four is a better motor with the one piece crank,
+1
congrats TG!
I think Corey has moved on to SV's, but I wonder if he will still campaign the ZX.
  • turboguzzi
20 Apr 2015 15:44
#668928
zuk, have you ever dynoed the motor? your tune state sounds a lot like mine
  • zukdave
  • zukdave's Avatar
20 Apr 2015 16:45
#668935
I did back when I put the VM29's on to see the A/F ratio
at 15 to 1 way lean it made 76 hp at the wheel.
Now with the fresh motor and way better jetting I'd say it's
high 80's or better.
I plan on calling the dyno guy this week and see about another dyno day.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • turboguzzi
29 Apr 2015 10:56
#669975
hei zuk, lets see waht you get jetted properly
my experience with the 810 kit was that as installed compression ratio was not high enough.
welded the heads quite a bit to get higher CR and larger squish areas.
  • zukdave
  • zukdave's Avatar
29 Apr 2015 16:06
#670022
TG when I had the head done Curtis took about 020 off the surface
so I'm thinking about 10 1/2 CR. I'd like it to be over 11 to 1 CR.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
