Drag strip trip. 26 Aug 2016 16:55 #740069
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
New box will be here Tuesday so I should have it wired and working for next weekend.
I think I'm gonna look at some kind of small onboard compresser so I can air shift on the
street and stop to keep fillin the bottle.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Drag strip trip. 26 Aug 2016 17:53 #740073
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2633
The Gold Wings had them. Nice to have. Any ideas where to get one?
Drag strip trip. 26 Aug 2016 17:58 #740075
  • SWest
  • SWest's Avatar
  • 10 22 2014
Warning: Undefined variable $itemid in /home/kzride5/public_html/libraries/kunena/bbcode/bbcode.php on line 262
No eBay APP ID and/or Cert ID defined in Kunena configurationI was looking at these. How much pressure do you need?
Drag strip trip. 26 Aug 2016 18:35 #740078
  • zukdave
Steve I need 100 psi in the tank at the first shift and that's enough for about six shift's
I've got a few small one in mind that will work just need to see which one is lightest
amd at what amp draw.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 26 Aug 2016 19:04 #740082
  • zukdave
Oh a change of game plan for going to the track turn's out next weekend is a JR dragster race all weekend
and we can't run bike's or car's.
Gonna put the trip off for a few week's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 26 Aug 2016 19:06 #740083
  • SWest
  • SWest's Avatar
  • 10 22 2014
That's quite a bit. I'm sure you know better about it than I do. Be interesting to see what you come up with. B)
Drag strip trip. 26 Aug 2016 23:58 #740107
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
  • Thank you received: 107
There are lots of small cheap 12 volt compressors on the market. They all have the following traits:
Noisy as hell, fast wearing and short lived, and slow to build volume at high pressure. But they are light weight and cheap, and they might work o.k. for filling an air shifter bottle....
One that I stripped out of an "Air-Man" hand held inflator weighs about one pound and is tiny - about the overall size of a golf ball, and can reach 140 psi.
Drag strip trip. 27 Aug 2016 17:36 #740180
  • zukdave
So at work we got these little Slime brand tire repair kit's it's a bottle of green goo
and a small 12 v. air compresser in a cute little bag.
Cost me 12 dollor's so got one plugged it the lighter in the van and hooked it to the air tank
and put 120 psi in the bottle pretty quick it worked a little hard but it did it.
So I took it apart to see what I could cut off the case to make it smaller few min. with a hack saw
it's mounted under the swing arm.
Ya I cut it already.
Used the switch and gauge still need to make a gauge mount but the switch and wiring are done
and the gauge work's. Black switch under the tach to the right turn's it on/off.
Test ride tonight made about 50 shift's and had no issue's about enough air.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 27 Aug 2016 17:44 #740182
  • SWest
  • SWest's Avatar
  • 10 22 2014
I've got a mini air compressor in my top box. Changed 4 tires since I got it.
I used one of my hole saws for wood to cut the holes for my gauges. Eats aluminum.
Drag strip trip. 30 Aug 2016 16:08 #740576
  • zukdave
Look what showed up today this will allow me to finish the auto shift set up.
Shift rpm is adjustable from about 2500 to 9,900 in 100 rpm step's and allow me to set the shift rpm for each gear.
Also has an adjustable ign. kill.
I think it fit's real nice right here. I'll have to move the fuse box but that's no big deal.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 30 Aug 2016 16:17 #740578
  • SWest
  • SWest's Avatar
  • 10 22 2014
Way cool. B)
Drag strip trip. 05 Sep 2016 12:14 #741208
  • zukdave
Got the shift control box wired and on the swing arm stand the bike was shifting all gears
so did a test ride and it seems it's not killing the ign. and wouldn't shift under load Not sure why
but I think it's in the setting I used for set up so I'll call tech support in the morning.
I moved the Dyna 2000 the start solenoid, voltage reg. and the fuse box to mount the shift control box
and still be able to get to both ends of the Dyna for programming.
Little pic's a video click it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
