- Thank you received: 2
Oil Flow Rate
- MJinCO
04 Jul 2024 10:39 #901749
by MJinCO
Oil Flow Rate was created by MJinCO
Has anyone found out what the oil flow rate is for the KZ1000J motor? Trying to size an oil cooler and they are all rated at mol 10gpm for a car motor.
- zed1015
- Thank you received: 1567
04 Jul 2024 11:30 #901751
by zed1015
Replied by zed1015 on topic Oil Flow Rate
Full width 10 row max for warmer climates and hard use.
Half width 10 row is generally sufficient.
If you have a long hose run you will need a stat to prevent oil delay to the cams etc on first start up.
