Oil Flow Rate
  • MJinCO
  • MJinCO's Avatar Topic Author
Oil Flow Rate
04 Jul 2024 10:39
#901749
Has anyone found out what the oil flow rate is for the KZ1000J motor?  Trying to size an oil cooler and they are all rated at mol 10gpm for a car motor.
  • zed1015
  • zed1015's Avatar
Re: Oil Flow Rate
04 Jul 2024 11:30
#901751
Full width 10 row max for warmer climates and hard use.
Half width 10 row is generally sufficient.
If you have a long hose run you will need a stat to prevent oil delay to the cams etc on first start up.
