- Thank you received: 2281
"J" clutch cover question
07 Jun 2024 04:21 #900411
by Wookie58
"J" clutch cover question was created by Wookie58
Hi all, is it possible to remove the "sight glass" for blasting and polishing and if so "how" please. I rather hear from someone who has done it than experiment
- zed1015
- Thank you received: 1548
07 Jun 2024 04:45 #900414
by zed1015
Replied by zed1015 on topic "J" clutch cover question
They just push in and out like a seal.
Pot luck how easy they come out and whether it remains reusable but i've had 99% success with them.
Push through the slot from behind with something that won't mark the glass such as wood or plastic.
Immersing the cover in hot water may help loosen its grip.
The following user(s) said Thank You: sf4t7, Scirocco, Wookie58
- Thank you received: 1655
07 Jun 2024 06:05 - 07 Jun 2024 06:09 #900419
by martin_csr
Replied by martin_csr on topic "J" clutch cover question
If needed such as if the seal is bad or not very tight, you could get a replacement sight glass with new seal. I've seen the part listed at various places. Partzilla has a photo w price and it was used on a lot of models, including a number of current models, so it should be readily available.
ps: z1enterprises svcks. maybe the change there was inevitable, but still. everybody calls that part a sight glass. Kawasaki lists it as an oil level gauge. z1 lists it as a "window", so you have to hunt for the darn thing.
Last edit: 07 Jun 2024 06:09 by martin_csr.
07 Jun 2024 06:31 #900422
by Wookie58
Replied by Wookie58 on topic "J" clutch cover question
- zed1015
07 Jun 2024 06:58 - 07 Jun 2024 06:59 #900424
by zed1015
Oil sight glass: Z-SERIES (GENUINE) (z-power.co.uk)
Yes! Z Power UK have genuine at around £25 and pattern for a fiver if your original one is too mullered to reuse.I never thought for a second these would be available as a "replacement part" thanks
Last edit: 07 Jun 2024 06:59 by zed1015.
07 Jun 2024 07:00 #900425
by Wookie58
Always nice to have a plan "B" if it ends up being the 1% that didn't go to plan
- sf4t7
- Online
- Thank you received: 343
24 Jul 2024 14:15 #902511
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replied by sf4t7 on topic "J" clutch cover question
Just replaced the oil sight glass in a used clutch cover I had. Used the old tip for installing bearing races - put the sight glass in the freezer for a couple hours, made it easier to push the sight glass into position from the outer side of the cover.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
The following user(s) said Thank You: TexasKZ, howardhb, Wookie58
- asphalt900
- Thank you received: 271
25 Jul 2024 04:10 #902526
by asphalt900
Replied by asphalt900 on topic "J" clutch cover question
Easy to do Wookie!! I do it all the time on the earlier thru 1980 covers but the sight glass is different and came in different styles of backer metal plate. Have a few genuine ones but You live sooo far away, ha.
25 Jul 2024 04:32 #902527
by Wookie58
Thanks Clay, if req Z-Power do an OE replacement for £25 (would probably cost that to ship from where you are) if I'm lucky (and careful) I should be able to re-use what I haveEasy to do Wookie!! I do it all the time on the earlier thru 1980 covers but the sight glass is different and came in different styles of backer metal plate. Have a few genuine ones but You live sooo far away, ha.
