  • Page:
  • 1
Cam end plug replacement 06 Apr 2024 11:56 #897321
  • sf4t7
  • sf4t7's Avatar Topic Author
  • Online
  • Thank you received: 258
So I'm replacing the old dried out rubber cam end plugs in the head with new aluminum ones this weekend.  What do you guys suggest - 3M weatherstrip adhesive or high temp silicone to seal them to the cutouts in the head?  (The gasket joint to the valve cover in that area will get a thin coat of silicone)
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Cam end plug replacement 06 Apr 2024 13:47 #897325
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
I'd use high temp engine RTV.  Coat the round area, just before install of the valve cover.
Cam end plug replacement 06 Apr 2024 19:44 #897331
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 86
Another thing to watch for is the fit. As you push the plug in it may bind at the lower portion of the head. If you measure the wall thickness it is thinner at the top of the half moon and thicker at the bottom of the head. The plug will bind. I end up having to file the ends slightly so to plug fiits nicely. I also use a small amount of high temp silicon. Never had one fit without binding
The following user(s) said Thank You: sf4t7, SWest, 78kawltd
Cam end plug replacement 06 Apr 2024 21:05 #897334
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
Same here
Cam end plug replacement 07 Apr 2024 01:56 #897335
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
  • Thank you received: 53
Yep, for many years the same, never a problem
  • Page:
  • 1
