  • Page:
  • 1
How to read a dwell meter 10 Oct 2023 21:58 #890335
  • ckahleer
  • ckahleer's Avatar Topic Author
  • Thank you received: 138
I have an old anolog dwell meter. It has a switch labled 4/8 cyl - 6 cyl.
I have an 82 kz305 and a 79 KZ400. The 305 has a set of points for each cylinder, and the 400 has 1 set of points for both cylinders.
Up till now, I have been setting points with a feeler gage, but would like giving this dwell meter a try.
What switch setting should I use, and is there a factor to multiply or divide the readings by?
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
How to read a dwell meter 11 Oct 2023 07:37 #890340
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 266
Mind you, it's been since the '70s,   but IIRC you will have to set it to 4/8 cylinder, and then multiply the reading by 4 for the twins... I think?
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
How to read a dwell meter 11 Oct 2023 10:14 #890349
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1814
Does the 305 have two "single output" coils and the 400 one "double outlet" coil (lost spark)
How to read a dwell meter 11 Oct 2023 11:44 #890353
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
I actually recently found my old Heathkit automotive tach/dwell meter I built in the seventies.
I would set the proper point gap with the feeler gauges then attach the dwell meter and fiddle around with the knob until you get a dwell reading you can deal with. Reverse engineering, sorta.
How to read a dwell meter 11 Oct 2023 13:02 #890356
  • ckahleer
Yes, The 305 has two sets of points and two single output coils. It has a 180 crank. When one piston is at TDC the other one is down.
The 400 has one set of points and 1 dual output coil. Pistons move up and down together.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
How to read a dwell meter 11 Oct 2023 13:09 #890357
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 373
Not sure if this will be of help or not but there are several topics/posts on this subject that a search will reveal.  I found this one to be of interest.
kzrider.com/forum/21-tools/616065-how-to...d-dwell-meter#850216
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
  • Page:
  • 1
