Piston Hole Kz1000LTD 1982 28 Dec 2023 18:48 #893246
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
For reference.  Drill-driven output shaft:
photos.app.goo.gl/eTk9hc1Rty5PnviD6
With crankshaft removed.
1982 KZ1100-A2
The following user(s) said Thank You: SWest, Mikaw, cartal, Wookie58
Piston Hole Kz1000LTD 1982 29 Dec 2023 04:15 #893273
  • cartal
  • cartal's Avatar Topic Author
  • Thank you received: 66
Thank you guys (yet again) for the replies. As I have already closed the cases, I feel a bit uneasy to try to connect the drill to the output shaft. I fear for the new cam chain. I´ve tried, but cannot figure out how to do such connection, and I definitely don´t spin it fast enough.
I will take your picture as reference that all my parts are correctly installed, and go from there.
Cheers.
C.
Piston Hole Kz1000LTD 1982 29 Dec 2023 07:10 #893277
  • zed1015
  • zed1015's Avatar
  • Away
  • Thank you received: 1473
If the clutch plates are removed the gearbox and clutch hub will spin but the outer basket and crank are isolated so can't be driven by the gearbox.
If you lay the engine on some wooden blocks on the clutch side you haven't got gravity working against you and the balls will roll outwards much easier with little rotational force and once you are in second the rest of the gears can be selected without having to spin the output shaft.
The following user(s) said Thank You: daveo, Mikaw, Wookie58
Piston Hole Kz1000LTD 1982 29 Dec 2023 12:46 #893285
  • daveo
  • daveo's Avatar
  • Premium Member
CAUTION:  What may be worthy of worry is for the life span of your drill, which may be dramatically shortened during this process.
1982 KZ1100-A2
The following user(s) said Thank You: cartal
Piston Hole Kz1000LTD 1982 31 Dec 2023 05:50 #893318
  • cartal
I may regret this later; but I looked and reviewed everything in the gearbox, and it looks OK. I could not find a way to adapt a drill to the shaft, so I´ve decided to move on. I have a solid first gear and a nice neutral. I´ll cross my fingers, and hope it works!
So, as I move on; engine is now "closed", and everything looks neat. New large bolts, and reused all the rest. No threads were damaged in the process... so we are ready to install the pistons now.
Happy to see some movement. Pics for reference, and for expert advice on any mistakes I may have made.
Cheers.
C.
Last edit: by cartal. Reason: pic ordering
Piston Hole Kz1000LTD 1982 31 Dec 2023 09:54 #893328
  • daveo
  • daveo's Avatar
  • Premium Member
Be sure to change out the old clutch push-rod o-ring while there is open access to it.
Ps.  It seems to help for viewing when a space is created between images as they are posted.
1982 KZ1100-A2
The following user(s) said Thank You: Street Fighter LTD, cartal, howardhb
Last edit: by daveo.
Piston Hole Kz1000LTD 1982 31 Dec 2023 17:53 #893365
  • cartal
Thank you. Had no idea there was an o-ring in there. Good tip for the pics. Will do now.
Happy new year!
Piston Hole Kz1000LTD 1982 01 Jan 2024 12:19 #893397
  • cartal
Pistons in place. Of course, I did drop a cotter pin into the oil pan, and had to take it off to get it. Of course it was the first one :-(
Anyway; all done now. Ready to get the cylinder block on. I have a question:
I don´t see any o-rings in the bottom of the cylinder block, just the gasket. Is that right?
I´m looking at this image, and I don´t see any. The manual says nothing about them.
Piston Hole Kz1000LTD 1982 01 Jan 2024 17:38 #893411
  • daveo
  • daveo's Avatar
  • Premium Member
No O-rings at the bottom, but 2 x 92043 locator dowels at the front outside studs...
Ps.  BTW, I have a couple extra brand new clutch-rod o-rings just laying around.
...or a-round?
1982 KZ1100-A2
Piston Hole Kz1000LTD 1982 03 Jan 2024 07:47 #893492
  • cartal
Thank you for the offer. The cost of postage and then customs, makes it impossible, though. This has gone out of hand!
Piston Hole Kz1000LTD 1982 03 Jan 2024 08:48 #893505
  • daveo
  • daveo's Avatar
  • Premium Member
Where would one tiny o-ring in an envelope need to be mailed?
1982 KZ1100-A2
Piston Hole Kz1000LTD 1982 05 Jan 2024 15:48 #893667
  • cartal
Madrid, Spain. Are you in the US?
