Piston Hole Kz1000LTD 1982 09 Mar 2024 12:54 #896224
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2081
Thankfully you will not be needing any, but in case anybody else does, you can get a set of eight genuine factory followers for only $214.24 from Webike.
japan.webike.net/ps/12032-1002/#!search&p.k=12032-1002
The following user(s) said Thank You: cartal
Piston Hole Kz1000LTD 1982 09 Mar 2024 13:54 #896225
  • cartal
  • cartal's Avatar Topic Author
  • Thank you received: 66
Zed, thank you. I can now confirm that it’s just a a question of a little sanding to get them going
I Built a little contraption with an isolation tube, so I could do it uniformly and at the same time protect the valve seal.
it has worked a treat. Saved a bunch of cash and time on this one!
The following user(s) said Thank You: zed1015, daveo, Rolf1976_KZ900
Piston Hole Kz1000LTD 1982 09 Mar 2024 14:17 #896228
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1473
Great news and a great idea with the insiulation.
Piston Hole Kz1000LTD 1982 09 Mar 2024 16:49 #896233
  • cartal
All set. Tappets move beautifully now. Oil all over…
Next.
The following user(s) said Thank You: asphalt900, daveo, sf4t7, Wookie58, Rolf1976_KZ900
Piston Hole Kz1000LTD 1982 10 Mar 2024 03:06 #896243
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
I've heard of a valve lapper but bucket lapper, think You just created a new tool!! Perhaps a patent pending is in order, ha Very resourceful!
Piston Hole Kz1000LTD 1982 17 Mar 2024 11:52 #896521
  • cartal
Some advance this weekend. Cams are in place. Would like your opinion on the pictures. Intake cam is spot on with the head line, but the exhaust looks a bit “up”. Do you guys think this is right? Everything turns nicely and was not as difficult as I expected.
My only real concern has been the bolts for the camshaft caps. Manual calls for 1.7 kg-m, and some of those bolts were “feeling” really soft for that torque. Have gotten all to 1.2 kg. Two of them won’t “lock”. Kinda scary.
I would appreciate your feedback on my “arrows”. Thank you guys!
The following user(s) said Thank You: Rolf1976_KZ900
Last edit: by cartal.
Piston Hole Kz1000LTD 1982 17 Mar 2024 11:56 #896522
  • cartal
Two more pics for clarity…
Last edit: by cartal. Reason: Alignment
Piston Hole Kz1000LTD 1982 17 Mar 2024 12:15 #896523
  • cartal
I was looking at Jonas’ thread on his engine rebuild and as Scirocco pointed out, I think I am one tooth off in my exhaust camshaft,
with the arrow pointing slightly upwards, but the indentation at the edge of the camshaft not being completely parallel to the head.
will have to redo it…
Piston Hole Kz1000LTD 1982 17 Mar 2024 12:32 #896524
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Off a tooth based on FSM illustration below:
1982 KZ1100-A2
The following user(s) said Thank You: cartal, howardhb, Rolf1976_KZ900
Piston Hole Kz1000LTD 1982 17 Mar 2024 12:55 #896525
  • cartal
Yes, Daveo, I’m afraid that is the case.
thank you!
Piston Hole Kz1000LTD 1982 17 Mar 2024 13:51 #896531
  • zed1015
  • zed1015's Avatar
Yes! It's one tooth retarded on the exhaust and on the inlet the marks won't line up until the camcover with chain guide is fitted.
Just make sure the tooth count from the exhaust to inlet cam is correct and you must not fit the tensioner until the cam cover is fitted.
Piston Hole Kz1000LTD 1982 17 Mar 2024 14:10 #896532
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Thank you received: 123
About the capbolts. I would not go higher than 12Nm on them and make sure the treadholes and screws are cleaned with carbclean and dry before torque them with a  wrench that is working good.
and forgot : when screwing them down use just half a turn on each screw in the pattern from manual.do not screw the hole screws down in one operation.
Last edit: by Rolf1976_KZ900.
