Spark Plug Hole Thread Repair 28 May 2022 16:22 #867827
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Thank you received: 632
Time-Sert time.
#3 spark plug hole is the culprit, and two others seem likey to become problems too.  May as well do them all while I'm at it
Which insert material is the best choice to use for a trouble free and permanent fix?
1982 KZ1100-A2
Spark Plug Hole Thread Repair 28 May 2022 16:54 #867832
  • gordone
  • gordone's Avatar
  • Thank you received: 67
I purchased a kit like these when I damage my threads some years ago, it has worked perfect since.
I think these is high quality, german quality?
www.klickparts.com/en/workshop/hand-tool...x1-25-kp1240261.html
Project:
Spark Plug Hole Thread Repair 28 May 2022 17:40 #867834
  • daveo
  • Premium Member
Need Time-Sert inserts and kit.  Only need four inserts made specifically for 3/4" spark plug thread length.
No desire to use aluminum inserts.  Steel inserts would work, but steel may/may not be the best material choice.
1982 KZ1100-A2
Spark Plug Hole Thread Repair 28 May 2022 17:50 #867836
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Würth aka Wurth Time Sert is the best.
M14 x 1,25 inserts are available in 7,0 / 8,0 / 9,4 / 11,0 / 15,0 / 16,8 mm length.
Last edit: by Scirocco.
Spark Plug Hole Thread Repair 28 May 2022 17:51 #867837
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
I should have gone Helicoil as I planned to do in the first place.
Spark Plug Hole Thread Repair 28 May 2022 18:08 #867841
  • daveo
  • Premium Member
1982 KZ1100-A2
Spark Plug Hole Thread Repair 28 May 2022 20:02 #867843
  • daveo
  • Premium Member
1982 KZ1100-A2
Spark Plug Hole Thread Repair 28 May 2022 23:20 #867845
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
  • Thank you received: 52
Eleven years ago I used a helicoil on cylinder two with the cylinder head in situ. No problems at all and bike is still going strong.
Spark Plug Hole Thread Repair 29 May 2022 08:53 #867864
  • daveo
  • Premium Member
Helicoil R513-10, 3/4" reach.  Would that be the correct length to use?
If the Helicoil fails, will a standard (NOT Big-Sert) M14 x 1.25 Time-Sert insert work to replace it?
Or...is the Helicoil Sav-A-Thread 5334-14 kit insert a better choice?
Ebay item 304009706232
1982 KZ1100-A2
Last edit: by daveo.
Spark Plug Hole Thread Repair 29 May 2022 10:09 #867866
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
First time my head came off  I put sparkplug inserts in .
Knowing how anal my buddies and I were with our Kaws it made sense.
 We were always tuning , checking , and changing  parts on our scooters to keep our edge over the rest of the Detroit crowd.
plugs to us were and still are a disposable commodity  in the search for a tenth advantage in a race
Happy Memorial Day Weekend
Spark Plug Hole Thread Repair 29 May 2022 11:43 #867867
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
Helicoil, Time-sert, or special spark plug insert, all will hold the spark plug in place if done correctly.
One question though: is heat transfer to the plug affected by the metal sleeve type inserts?  I suspect it changes things, but maybe not enough to matter?
Spark Plug Hole Thread Repair 29 May 2022 11:58 #867869
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Time Sert inserts are copper plated for the heat transfer.
