78 kz650 exhaust options?
- katit
08 Dec 2020 13:39
I have pretty rusted exhaust on bike I got (see pictures). It's 4->1, can you identify what it is?
Questions.. Is it salvageable or it is junk?
Other parts bike I got has those chrome runners but no mufflers. Little rust. Any use for those?
What is the best course of action now? Make it work good and make it look good. Pointers?
Re: 78 kz650 exhaust options?
08 Dec 2020 16:24
I don't think the 4 to 1 is junk. First I'd remove it and inspect it closely and check for thin areas. If its solid, you can get it ceramic coated. Personally id lean toward restoring it as most of the older exhaust are better made.
08 Dec 2020 16:38
That header looks like a MAC. It's pretty much the lowest form of a header but serviceable enough. The stock pipes looks to have had their mufflers sazsall'ed off. Other than the removeable pieces I'd send them to the trash can.
- gd4now
- Denco where did you go?
09 Dec 2020 10:08
From the pics you posted it would appear to me that either system could be usable. It is dependent upon what you want for your machine. Take the 4 into 1 off and take it to bare metal and see what you have. Any pin holes or thin locations? If not paint it with high temp header paint or get it coated. As to the stock set there are mufflers that could be added to it.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- katit
09 Dec 2020 10:28gd4now wrote: From the pics you posted it would appear to me that either system could be usable. It is dependent upon what you want for your machine. Take the 4 into 1 off and take it to bare metal and see what you have. Any pin holes or thin locations? If not paint it with high temp header paint or get it coated. As to the stock set there are mufflers that could be added to it.
Will do. For the stock set, which mufflers can be used? Where to find? I checked all sites - NA everywhere
09 Dec 2020 10:48 - 09 Dec 2020 11:02
Amazon has universal motorcycle mufflers. Some sort of adapter will have to be welded to the stock pipes in order to mount them.
Last edit: 09 Dec 2020 11:02 by Nessism.
- katit
09 Dec 2020 10:54Nice, I see. Then I won't throw away those 2->1 headers for nowNessism wrote: Amazon has universal motorcycle mufflers. Some sort of adapter will have to be welded to the stock pipes in order to mount the mufflers.
09 Dec 2020 11:06
The photo below shows what your exhaust looked like before someone hacked off the muffler. It's one piece from new and the muffler is not removeable. Again, you would have to weld on some adapters. Personally, I'd focus on the header first.
- katit
09 Dec 2020 12:49Nessism wrote: Personally, I'd focus on the header first.
What do you mean by that?
09 Dec 2020 16:10katit wrote:Nessism wrote: Personally, I'd focus on the header first.
I'd focus on trying to clean up the header and get it repainted, assuming it's not all bashed up on the bottom. Messing around with trying to get mufflers installed where the old ones were cut off would be last resort to me.
