  • Page:
  • 1
  • 2
Seal by shift lever 22 Apr 2009 15:40 #284137
  • Darkangel
  • Darkangel's Avatar Topic Author
  • Thank you received: 0
Right where my shifter is..there is a leak...where can I find the seal for it....and how hard is it to replace.
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
Seal by shift lever 22 Apr 2009 15:51 #284141
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
Check and see if the leak is coming from the alternator grommet. This kind of leak on these older bikes is easy to fix. Go to www.z1enterprises.com and ask about the grommet.
It's price was $12.38(not sure about current price) while you're at it order a gasket for the alternator side as the old one will tear on removal.
The wires will have to be cut,inserted through the new grommet, and then spliced.
Tilt the bike to the right to minimize the oil flowing out(maybe a cup).
If the leak is not the alternator grommet and it's the shifter shaft, then the sprocket cover will have to be removed, the engine sprocket and the chain to access the seal on the shifter shaft.I think z1 enterprises sells the seal.
Seal by shift lever 22 Apr 2009 18:23 #284188
  • pburnhamb
  • pburnhamb's Avatar
  • Thank you received: 2
Bikebandit has the seal i bet. I just ordered one for my 650. there are great pictures and exploded views on there to help you choose the right seal and to see what you will need to remove to replace it. I* bet its not too hard. just patience
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
Seal by shift lever 23 Apr 2009 18:38 #284575
  • y2kwu8
  • y2kwu8's Avatar
I just got one for my KZ550H2 at the local Kawasaki dealer for $6.00. Not sure if it is the same set-up, but I had to remove the shifter lever, then the counter shaft sprocket cover, and replace the shifter shaft seal. It was that simple. Mine was leaving a large puddle because the bike sat so long and now it is as dry as a bone. If you use the parts diagrams on the Kawasaki website, it'll even tell you if the part is still active when you click on the part number. www.kawasaki.com/DefaultFrame.aspx?strCo.../VICHOOSEVEHICLE.ASP
Currently in the Garage:
1983 KZ550H2 Gpz550
2004 ZZR1200
1989 NT650 Hawk GT
2007 ZZR600
2004 HD Night Train
Last edit: by y2kwu8.
Seal by shift lever 29 Jun 2009 18:53 #303191
  • Darkangel
Can someone give me a direct link to were I can find the shifter seal?
Seal by shift lever 29 Jun 2009 20:15 #303243
  • brianrae33
  • brianrae33's Avatar
z1 sells them..it's just called a shift shaft seal..like 2 or 3 bucks..but you have to heat the cover to get the seal out..212 degrees i believe..
1982 kz1000ltd
Seal by shift lever 29 Jun 2009 20:52 #303259
  • Darkangel
Yeah...I am not finding it over at Z!E
Seal by shift lever 29 Jun 2009 20:56 #303262
  • Thank you received: 2098
Also didn't see it listed at Z1E.
Could inquire by email.
Good Luck! :)
Seal by shift lever 30 Jun 2009 07:35 #303331
  • brianrae33
call them..i know they carry them because that's where i got mine..sometimes parts aren't listed on the website for some reason..
1982 kz1000ltd
Seal by shift lever 25 May 2023 06:39 #885168
  • 29mmgas
  • 29mmgas's Avatar
I would like to know if anyone has changed the bushing in the outside countershaft sprocket cover directly where the shift lever is. It might have to be pressed out and a new one pressed in but I don’t want to take a chance and crack the cover. I do need to replace the seal but there is some play in the bushing as well. I don’t want to just replace the seal and have to replace it again any time soon. Any thoughts on this?
Seal by shift lever 25 May 2023 07:53 #885172
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
Is there a bushing in the cover presently?  I don't recall seeing that before.  Most bikes have the shifter shaft riding straight on the aluminum cover.  Anyway, it should be possible to install a bushing, or replace a worn busing, assuming you have the proper tools.  A bushing could be cut on a lathe, and pressed into the cover after you ream it to an appropriate size.  That sounds like a fun project.  Of course, check for shaft wear as well.
Seal by shift lever 25 May 2023 08:19 #885173
  • 29mmgas
  • 29mmgas's Avatar
There is what appears to be a brass bushing. I will check for the wear on shift lever also. Thanks for the good info!
  • Page:
  • 1
  • 2
