Z2 750 crank (Bossie the Kaw) 01 Aug 2020 15:33 #832047
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2621
They seem to work. B)
Z2 750 crank (Bossie the Kaw) 01 Aug 2020 15:38 #832049
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
You can get the length of any bolt from the Partzilla parts diagrams. The long ones are Part # 112G06125. The last 5 numbers indicate that it's a M6 bolt, 125 mm long.
Z2 750 crank (Bossie the Kaw) 01 Aug 2020 19:20 #832059
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
SWest. Glad to see so far they are working out. If the bolt is bottoming out, could you just cut 1/4” of thread off?
Z2 750 crank (Bossie the Kaw) 01 Aug 2020 20:52 #832072
  • SWest
  • 10 22 2014
That's what they say you might have to do.
Z2 750 crank (Bossie the Kaw) 02 Aug 2020 06:54 #832095
  • SWest
  • 10 22 2014
Now to RIDE. :woohoo:
Z2 750 crank (Bossie the Kaw) 04 Aug 2020 18:45 #832244
  • SWest
  • 10 22 2014
They were glazed.
Z2 750 crank (Bossie the Kaw) 04 Aug 2020 21:13 #832257
  • SWest
  • 10 22 2014
I should have cleaned all the plates.
Z2 750 crank (Bossie the Kaw) 05 Aug 2020 06:29 #832272
  • Greybeard
  • Greybeard's Avatar
Are those springs still in spec?
1982 KZ1100 D-1
Z2 750 crank (Bossie the Kaw) 05 Aug 2020 06:45 #832273
  • SWest
  • 10 22 2014
Well over spec. It must have been the pre mix I'd been using to flush out the engine.
The following user(s) said Thank You: Greybeard
Z2 750 crank (Bossie the Kaw) 06 Aug 2020 15:17 #832345
  • SWest
  • 10 22 2014
Should have done this the first time.
Z2 750 crank (Bossie the Kaw) 06 Aug 2020 19:44 #832352
  • SWest
  • 10 22 2014
Looks like it will work.
Z2 750 crank (Bossie the Kaw) 11 Aug 2020 07:44 #832648
  • SWest
  • 10 22 2014
More to do but at least I can ride.
