Z2 750 crank (Bossie the Kaw) 11 Jul 2020 19:34 #830419
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2620
Love getting things for the bike. B)
Z2 750 crank (Bossie the Kaw) 12 Jul 2020 17:44 #830492
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
Why are you splitting the cases?
Z2 750 crank (Bossie the Kaw) 12 Jul 2020 18:46 #830499
  • SWest
  • 10 22 2014
Replacing the transmission. Noise and popping out of second.
Z2 750 crank (Bossie the Kaw) 12 Jul 2020 20:31 #830510
  • hardrockminer
Oh dear! Noise...is it just bearings? Popping out of second...may be just the forks?
Z2 750 crank (Bossie the Kaw) 12 Jul 2020 20:44 #830512
  • SWest
  • 10 22 2014
Maybe. We'll find out. :unsure:
Z2 750 crank (Bossie the Kaw) 13 Jul 2020 06:55 #830544
  • SWest
  • 10 22 2014
I'll try to pull the engine tomorrow.
Z2 750 crank (Bossie the Kaw) 13 Jul 2020 08:47 #830549
  • hardrockminer
I'm interested in what you find. I have a whine in one of my bikes and I think it's a transmission or clutch bearing.
Z2 750 crank (Bossie the Kaw) 13 Jul 2020 14:01 #830583
  • SWest
  • 10 22 2014
I would think the whine would be from the primary drive gear/input. The clutch basket bearing could be shot. I felt no slop in the sprocket bearing or the clutch bearing when I was in there. I've had second gears pop out but this one's new to me.
Last edit: by SWest. Reason: sp
Z2 750 crank (Bossie the Kaw) 13 Jul 2020 22:03 #830617
  • SWest
  • 10 22 2014
Pulling the engine in the morning.
Z2 750 crank (Bossie the Kaw) 15 Jul 2020 07:04 #830710
  • SWest
  • 10 22 2014
Took some doing but I got it out. B)
The following user(s) said Thank You: Greybeard
Z2 750 crank (Bossie the Kaw) 15 Jul 2020 07:50 #830717
  • Greybeard
  • Greybeard's Avatar
Try putting a heat gun on that gasket and see if it softens up and releases.
What about a piece of steel across the ceiling and a good strap to hold the weight of the motor to help get it back in?
1982 KZ1100 D-1
Last edit: by Greybeard. Reason: Addition
Z2 750 crank (Bossie the Kaw) 15 Jul 2020 07:57 #830720
  • SWest
  • 10 22 2014
I'll give that a shot. B)
