Z2 750 crank (Bossie the Kaw) 12 Feb 2020 14:11 #819109
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
My pleasure, Steveo.
Now RIDE THE PISS OUT OF IT!!!
:woohoo:
1982 KZ1100-A2
Z2 750 crank (Bossie the Kaw) 12 Feb 2020 19:14 #819134
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2621
Doin just that. :woohoo:
Z2 750 crank (Bossie the Kaw) 12 Feb 2020 22:08 #819139
  • daveo
  • daveo's Avatar
  • Premium Member
Must be years since you last made her scream like that. Youza baby!
Loving every 2nd of it 2 :woohoo:
:whistle:
1982 KZ1100-A2
Last edit: by daveo.
Z2 750 crank (Bossie the Kaw) 13 Feb 2020 08:02 #819159
  • SWest
  • 10 22 2014
I think the porting helped too. B) The new head had been decked so that may have changed things. :unsure:
Not the first time I've run into this issue.
Z2 750 crank (Bossie the Kaw) 14 Feb 2020 18:28 #819338
  • SWest
  • 10 22 2014
Still trying to get the plug to stop leaking.
Z2 750 crank (Bossie the Kaw) 14 Feb 2020 21:59 #819354
  • daveo
  • daveo's Avatar
  • Premium Member
That little-voice has been whispering since I set the head on my new set of pistons and bores.
Cuda shuda checked the valves and seals, but I reasoned not to listen.
Had plenty time and was able to do it.
:pinch:
Hope it won't matter, but I'll go back in post-riding season if it is needed.
1982 KZ1100-A2
Z2 750 crank (Bossie the Kaw) 15 Feb 2020 06:26 #819360
  • SWest
  • 10 22 2014
Best to do it before all that black carbon builds up. That's what screwed up both of my bores. I'll be going back in to replace the guide seals AGAIN. :angry: I'll have the plug hole repaired at the same time.
Z2 750 crank (Bossie the Kaw) 16 Feb 2020 06:59 #819425
  • SWest
  • 10 22 2014
I have an idea. See if it works.
Z2 750 crank (Bossie the Kaw) 18 Feb 2020 06:19 #819519
  • SWest
  • 10 22 2014
Looks like welding won't be an option at least for now.
I did find a Time Sert kit I can afford. In the meantime I'll try this.
Z2 750 crank (Bossie the Kaw) 19 Feb 2020 06:57 #819571
  • SWest
  • 10 22 2014
The saga goes on.
Z2 750 crank (Bossie the Kaw) 19 Feb 2020 18:17 #819597
  • SWest
  • 10 22 2014
Got a new one in.
Z2 750 crank (Bossie the Kaw) 20 Feb 2020 07:07 #819611
  • SWest
  • 10 22 2014
I'll just have to wait until I get the kit. :unsure:
