Z2 750 crank (Bossie the Kaw) 28 Mar 2020 18:57 #822071
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2619
The rings aren't seating. I need to take a long trip then maybe they will.
Z2 750 crank (Bossie the Kaw) 29 Mar 2020 15:04 #822140
  • SWest
  • 10 22 2014
The plugs are looking better and the insert isn't leaking.
Z2 750 crank (Bossie the Kaw) 30 Mar 2020 21:16 #822246
  • SWest
  • 10 22 2014
They were leaking.
Z2 750 crank (Bossie the Kaw) 31 Mar 2020 19:19 #822343
  • SWest
  • 10 22 2014
They work.
Z2 750 crank (Bossie the Kaw) 01 Apr 2020 13:50 #822408
  • SWest
  • 10 22 2014
More progress
Z2 750 crank (Bossie the Kaw) 02 Apr 2020 11:54 #822481
  • SWest
  • 10 22 2014
I think the jetting is good just these 33's are a PTIA to dial in. :unsure:
Z2 750 crank (Bossie the Kaw) 02 Apr 2020 18:23 #822501
  • SWest
  • 10 22 2014
I got it really close. Only a slight miss at 4000 from one carb. I'll get it. Not done with the plug insert yet. :dry:
Z2 750 crank (Bossie the Kaw) 05 Apr 2020 20:11 #822681
  • SWest
  • 10 22 2014
Got this done now for the insert.
Z2 750 crank (Bossie the Kaw) 06 Apr 2020 20:02 #822769
  • SWest
  • 10 22 2014
Took two tries but I got it. B)
This is a condensed version
Z2 750 crank (Bossie the Kaw) 07 Apr 2020 09:23 #822798
  • SWest
  • 10 22 2014
Looks like it's good to go. :woohoo:
Z2 750 crank (Bossie the Kaw) 07 Apr 2020 09:31 #822799
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
Diligence is worth it in the long run.
The Dynatek solid core plug wires with NGK Resistor caps have 5+ ohms resistance, and the Taylor Resistor Core wires with Non-Res Accel caps have 3.8
Go figure
:S
P.S. With NGK BR8EVX Resistor spark plugs, I thought there would be an excessive resistance problem with the Taylor Resistor Core wires.
But, that doesn't seem to be. I don't get that, because I seemed to have an issue using the NGK Resistor Caps and those same Resistor plugs some time ago.
1982 KZ1100-A2
Last edit: by daveo.
Z2 750 crank (Bossie the Kaw) 07 Apr 2020 10:42 #822805
  • SWest
  • 10 22 2014
The caps I have are non resister. I'd like to get some blue Taylor wires though. :whistle:
