76 KZ900
  • mvent
  • mvent's Avatar Topic Author
Re: 76 KZ900
27 Mar 2023 14:57
#882089
Experimenting with different products to clean engine and covers before removing from frame.
Before and after
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • TexasKZ
  • TexasKZ's Avatar
Re: 76 KZ900
27 Mar 2023 17:06
#882092
Perhaps that should say after and before
  • mvent
Re: 76 KZ900
27 Mar 2023 17:28
#882097
Was hoping no one noticed that lol
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • TexasKZ
  • TexasKZ's Avatar
Re: 76 KZ900
27 Mar 2023 17:38
#882099
Which product did you like best.
  • mvent
Re: 76 KZ900
28 Mar 2023 18:01
#882137
I think any cleaner that won’t harm the aluminum will work it’s the scotch pad and nylon brush that does the hard work along with WD40.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • mvent
Re: 76 KZ900
06 Apr 2023 14:25
#882575
Still having problem on 4th cylinder. Did another compression check with same results as before. Did leak down test and all cylinders less than 10% leak down, 4th cylinder had least amount. Switched plug wires and plugs same result. When starting cold after sitting couple of days, no smoke out tailpipe. Stuck clear hose in 4th carb bowl and fuel level went to joint where bowl meets carb body. When first starting pipe all cylinder fire and all exhaust pipes get hot pretty evenly, after 2-3 minutes of idling shutting off check as it warms up 4th cylinder pipe starts to cool off. When riding it I noticed whenever throttle is open more than half way regardless of rpm or gear it clears up and pulls strong. I’m thinking float level is too high, anyone agree?
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 76 KZ900
06 Apr 2023 14:50 - 06 Apr 2023 14:51
#882576
Check the valve lash. When the engine heats up, valves like to expant and the valve clearance can go to near zero.
Some rust or carbon build up on the valve seat surface and seat rings in the cyl. head can make a lot of trouble!
A cheap USB Handy bore scope can help to give you some more internal view to the piston dom, cylinder bore and valve condition.
Last edit: 06 Apr 2023 14:51 by Scirocco.
  • mvent
Re: 76 KZ900
09 Apr 2023 08:34
#882794
Torqued cam cap bolts to check valve clearances, can’t get my smallest feeler (.038) in between shim and cam on cylinder I’m having an issue with, maybe I found the problem. Thanks Scirocco
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • mvent
Re: 76 KZ900
10 Apr 2023 16:42
#882878
Loosened valve clearance on trouble cylinder and no change. Replaced choke plunger with one from another carb no change. Rode about 15 miles, it’s only missing at small throttle opening regardless of RPM, when opening throttle beyond 1/3 to half throttle it pulls strong even from low (2000) RPM. Decided to do a running compression test. Hot engine open throttle I have 150 lbs of cranking pressure, added teaspoon of 50 weight oil jumped to 160. Started engine and gauge goes to 30 at 1500 RPM blip throttle to 2500-3 k RPM jumps up to 60-70 lbs. I’m thinking intake problem ? Excess carbon on intake valve or seat? Feedback appreciated. No smoke out exhaust noticed.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • mvent
Re: 76 KZ900
24 Apr 2023 17:49
#883697
Have it mostly stepped down, engine out. Wheels and suspension later this week then off to sandblaster/ powder coater.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • sf4t7
  • sf4t7's Avatar
Re: 76 KZ900
24 Apr 2023 20:46
#883703
How do the rubber manifolds between carbs and head look?  Mine had some hairline cracks, barely visible.  Z1E has them.
Scotty
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: 76 KZ900
25 Apr 2023 00:16
#883704
I think it's unlikely to be a carbon build up issue, how old are the plugs and HT leads? Is the ignition advancer moving freely? What condition are the intake rubbers in (as already mentioned)? Are the pilot circuits in the carbs clean?
