And finally, Wookie's 82 begins !
  • blackozvet
  • blackozvet's Avatar
Re: And finally, Wookie's 82 begins !
28 Sep 2022 06:07
#874740
You have certainly bitten off a lot to chew Wookie - keep at it !
1973 Z1 900 Kawasaki
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Away
  • Moderator
28 Sep 2022 07:10
#874748
It all started as a Z1 tail piece conversion
  • Wookie58
  • Away
  • Moderator
08 Oct 2022 11:58
#875269
I haven't touched the bike for a couple of weeks as last weekend I took Mrs Wookie to London. 3 years ago I bought concert tickets for her birthday but it was cancelled due to Covid so last weekend she got her wish to see Andrea Bocelli (not exactly wild rock gig but excellent just the same a I think she might be too classy for me)
So today I started on the other side panel ( I Promise it will get more interesting soon) what a PITA that turned out to be, the first one wasn't too bad to do but the right hand side is an aftermarket panel which is a different plastic ( thicker, harder and not ABS) it reacts to heat differently, the curvatures are a little off and it resists the "hot rivets" to make the joins but we have got there in the end (I have left it for the glue to set now and will start sanding in the morning
  • Wookie58
  • Away
  • Moderator
09 Oct 2022 10:17
#875287
So I now have a matched pair of side panels, I have put the flange in for the lower mounts (will trim once I have decided where the mounts will be) feeling good
  • Jonas_Z1000j
  • Jonas_Z1000j's Avatar
09 Oct 2022 11:38
#875289
Very nice!
I guess you have the original mounts left and will reallocate those? Or will you fabricate new ones?
One of mine have broken off and is missing, I have been poundering if I should fabricate something or get a new panel..maybe you have some ideas for this?
Z1000 J2 -82 not so running restoration object anymore
Z900RS -21 Green/Yellow
  • Wookie58
  • Away
  • Moderator
09 Oct 2022 11:53 - 09 Oct 2022 12:16
#875290
Very nice!
I need to fabricate almost everything on this build, the original frame mounts are gone and the panels are a totally different shape now. I will pick up the bottom mounts from the extra tubes I put in to brace the frame for the mono-shock conversion
Have you got the piece that broke off your panel ?
Edit: just saw that it is missing  maybe you could find what you need on a different panel (or just bite the bullet and buy new) I am only going to all this hassle because I can't buy panels that would fit the way I want with the frame mods and one- off seat
Last edit: 09 Oct 2022 12:16 by Wookie58.
  • Wookie58
  • Away
  • Moderator
18 Oct 2022 14:30
#875685
Just dropped a winning bid on a small lathe, don't tell Mrs Wookie
The following user(s) said Thank You: Street Fighter LTD, slayer61, Nerdy
  • blackozvet
18 Oct 2022 21:28
#875699
She will realise when you start spending endless hours in the garage making small intricate things !
  • Wookie58
  • Away
  • Moderator
22 Oct 2022 10:52 - 22 Oct 2022 10:52
#875846
Happy to report that the saga of the sidepanels is drawing to a close, got the mounts sorted today so just a bit of fine tuning and they will be ready for bodyworking
Last edit: 22 Oct 2022 10:52 by Wookie58.
The following user(s) said Thank You: blackozvet
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
22 Oct 2022 18:44
#875853
Go Wookie Go !!!!!
  • Wookie58
  • Away
  • Moderator
30 Oct 2022 11:45 - 30 Oct 2022 13:13
#876204
More thrashing on plastics this weekend, have got the mods done on the rear inner fender (to clearance other components) just needs tidying up and trimming now once the bonding etc has had time to set properly. I have included a pic of an original for those not familiar with how it used to look. Also started bending a sheet of ABS to make the finishing panel that will replace the original fender
Last edit: 30 Oct 2022 13:13 by Wookie58.
  • Wheelhop
  • Wheelhop's Avatar
30 Oct 2022 16:01
#876218
Looks like you have a little room under there for a bottle of Nitrous!
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
