1973 Z1 Maui 10 Sep 2021 10:35 #855107
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1807
As I R.E.M. er Avon Roadrunners where the tyre of choice in the late 70's and where excellent in the wet ( I just looked and they are still available on the net)
1973 Z1 Maui 12 Sep 2021 12:18 #855172
  • MauiZ1
  • MauiZ1's Avatar Topic Author
  • Thank you received: 19
As I slowly get ready to assemble things I'm finding a few issues. Of course I did not take enough photos, at least of the things I need to see now and this bike had a lot of stuff that was not "as built" so I'm having trouble with the battery box/ regulator/center harness/starter solenoid area. I've got most of it figured out with the help of Marsden and Brookes books and the parts and shop manuals but it would be great to get a few photos of an early Z1 in this area. Mine was built in 10/72. I'd like to see, if I can, exactly how the little wiring tab is mounted. Piece 58 on page 41 of the parts manual. Also I don't think I've got the start solenoid bracket properly sorted out. I have new rubber bushings for it but they don't seem right, do they have metal collars in them?
Any photos in this area will be greatly appreciated.
Thank you
1973 Z1 Maui 12 Sep 2021 13:36 #855176
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
There are two hooks for the harness under the four connectors.
There is a hook for the tail light harness harness on back of tool tray.
1973 Z1 Maui 13 Sep 2021 08:05 #855211
  • MauiZ1
How about the start solenoid? I assume there is rubber grommets under the fender washers? Are there metal bushings in the grommets if they are there or is the solenoid just bolted down metal to metal?
Thank you for the photo
1973 Z1 Maui 14 Sep 2021 06:19 #855245
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 606
There are steel sleeves inside the grommets.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
1973 Z1 Maui 14 Sep 2021 20:01 #855273
  • MauiZ1
I made a blast cabinet from the cardboard box the compressor came in. It was very crude but for a first attempt it did what I wanted it to do and that is limit (somewhat) the loss and spread of glass beads. I started with a little hopper gun which was terrible. It worked but it was too bulky for the box. My siphon gun arrived which worked much better. I had installed gloves in the box but they were way too hard to use, I abandoned them. I learned from this that had I purchased a blast cabinet It would have been too small, it takes a pretty good size box to wrestle the engine parts around. Good learning experience. I achieved what I feel is a paintable surface which is what a 73 needs. Had it been a 74 I would have needed more aggressive media to get a nice clean bare alloy surface. The head was by far the hardest part with the deep fins. The glass gets everywhere. Just for fun I’m going to try some baking soda to compare. The compressor was fine, I had to let it catch up every 10 minutes or so but I also needed a break to to reposition and scoop up beads. My filter drier seems to work well. Had I wanted a bigger compressor the price really goes up between 30 gallons and 60 gallons, and I don’t have room for one. All in all, a sweaty, hard work success. Now for the intensive clean up. I used about 15 pounds of fine glass some of which I’ll strain and recover.
The following user(s) said Thank You: BCScott
1973 Z1 Maui 15 Sep 2021 14:54 #855308
  • MauiZ1
I’m removing the blanks and my system has only leaked a very small amount of glass near the starter hole. I’ll still clean it thoroughly but it’s nice to know it’s not packed with beads.
1973 Z1 Maui 15 Sep 2021 15:46 #855310
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Good job, I'm not far off going through this process myself...
1973 Z1 Maui 16 Sep 2021 07:37 #855336
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 437
Another fine use of duct tape! Nice!
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
1973 Z1 Maui 16 Sep 2021 07:49 #855337
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1863
Fine job your doing there Doc Brown. Do you compressor run off of 1.21 gigawatts.
1973 Z1 Maui 16 Sep 2021 08:07 #855338
  • MauiZ1
Compressor is 115v. I'm thinking of converting it to 240v and making a long extension of heavy wire to the nearest plug I have which is a 30 amp twist lock I run my table saw from. It worked ok for the job though, I only had to wait a little bit.
I must have used $25 of cloth tape!
I've used many rolls of painters tape on this project. More to come in preparation for painting,
1973 Z1 Maui 17 Sep 2021 14:51 #855416
  • MauiZ1
So I’m checking the valves out. The guides and valves were done in 2009 and I’m sure there wasn’t much wear since then. The exhaust seem fine but the intakes seem loose. I just ordered a small bore gauge to get an accurate measurement but in the mean time I used the dial indicator method in the shop manual. The exhausts come out at the top of the service limit using that method. I’m not too sure that’s accurate but they also feel loose. I’m going to coat the stems with oil and see how they feel then.
They blue checked fine but I will still do a light lapping to clean the seats and faces up a bit.
I have new seals for it but I will wait to take accurate measurements of clearance.
