- Thank you received: 260
And so it begins... 1976 KZ750B Twin barn find project.
- Skidmark
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
- azman857
- Thank you received: 111
- Thank you received: 2817
azman857 wrote: Just a thought..All that rust that was removed off the chain was steel. Lost strength due to removed metal. Increased clearances to allow more vibrations.Please give a thought towards new chain and sprockets.
Removing the rust didn't weaken it. The bigger question is how worn is it? and of course those stiff links are not good. Personally, I'd swap it out for a 530 setup. New chains are drastically improved compared to how they were 45 years ago so it's money well spent.
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2829
This happens is because even though it may not appear obvious to the naked eye as sprockets wear they gain a somewhat different gap between the teeth. A new chain will rather quickly wear so that it matches that gap, and that causes the chain to wear out prematurely. Likewise, a worn chain has somewhat different spacing between links than a new chain, and that slightly wider gap will cause the new sprockets to wear rather quickly so the gap between the sprocket teeth will match the chain.
All this seems rather subtle until one discovers the new item wears out quickly. Replacing the chain and both sprockets ensures that the sprockets teeth gap and the chain link length are a perfect match, and that ensures that the chain and sprockets will last quite a long time.
- ThatGPzGuy
- Thank you received: 385
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- nk140
78 KZ750B
- Skidmark
Retired gearhead
'81 KZ-750 E2
- mitchm114
- ThatGPzGuy
That has got to be some kind of recordTook the rust off the chain. Still works just fine! :silly:
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
