Katit's 1978 KZ650 project 26 Jul 2022 18:27 #871092
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
All plating done! Now to assembly. Was waiting for wheel locks to plate, now I was able to mount tire. It is PITA, but wasn't bad, really. I guess I am getting good at it. Even with wheel locks it was fine. Of course I first forgot to put rim tape, good thing I realized it before putting other side of tire in. Then, I forgot to make holes in rim tape (heated bolt with a torch and melted them through). Then I put valve stem into wrong hole. Anyhow, som busted knuckles and it's done. No pinched tubes :)
Next will be roller. I want this thing to be move-able. At what point is it easiest to put motor in? Should I do it while I have just a frame?
Last edit: by katit.
Katit's 1978 KZ650 project 27 Jul 2022 09:31 #871125
  • katit
Any advice on that? I figured I will need some help, but what is the best time for engine to go in?
Katit's 1978 KZ650 project 07 Aug 2022 16:21 #871841
  • katit
Some more progress. Rear wheel installed, I didn't torque anything yet (where I may take it apart again)
Front end - assembly in progress. All nice chrome, bolts, chased/cleaned threads. Coming together nicely so far (questions in separate topic on triple tree). Roller will be ready soon!
Katit's 1978 KZ650 project 07 Aug 2022 16:33 #871845
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1865
Looks great. The wear pointer is on the wrong end of the range. It needs to be near the “e” of range.
Katit's 1978 KZ650 project 07 Aug 2022 16:36 #871846
  • katit
 Will move it! :) Just put it on so I don't lose it. Btw - bought 1/4 piece of black felt to make that dust seal behind pointer.
Katit's 1978 KZ650 project 08 Aug 2022 18:17 #871900
  • katit
Looking like a roller. Just loosely assembled, but it's portable now. Ready for engine.
Brakes assembly in progress
Katit's 1978 KZ650 project 08 Aug 2022 18:31 #871902
  • Mikaw
  • Mikaw's Avatar
It’s a roller! Not picking but want you to be safe, and maybe this is just your “assembled loosely” but your front axle clamp are not correct. The front nut gets tighten first, then the rear leaving the gap in the rear.
Katit's 1978 KZ650 project 08 Aug 2022 19:05 #871903
  • katit
Hey! I appreciate it. Also it is loose assembly- I want to know about things.
when I do final - I read book for torque values so it probably will be mentioned there. But anyways- reason for posting all the pictures is so people see and perhaps notice stuff.
on brake disks I did final torque on bolts but didn’t bend those lock washers just in case..
Katit's 1978 KZ650 project 08 Aug 2022 23:52 #871908
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1816
The bike is looking really good Katit, you have done a great job over a short time scale
The following user(s) said Thank You: katit
Katit's 1978 KZ650 project 09 Aug 2022 02:45 #871911
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1905
As Mikaw mentioned, the axle clamp has a arrow mark that has to be pointed into the driving dircetion.
Katit's 1978 KZ650 project 09 Aug 2022 05:25 #871917
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1033
Newer models have the arrow.  Older ones don't.
Katit's 1978 KZ650 project 09 Aug 2022 05:52 #871918
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Sorry to say hardrockminer but this screen shot was taken from the first 1976 service manual.
