Katit's 1978 KZ650 project 03 Jun 2022 08:47 #868132
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
My OCD just won't let me rest. No, I am not going to leave painted parts as is. I did downgrade to spray bombs for frame (VHT frame/roll cage). I tried to use it per instructions but still got runs when did swingarm (it's on picture prepped).
Prepping - I have to sand every bit now. Orange peel from previous prime/paint is too much for my taste so I sand it all down. Good thing everything is dry and not too bad to sand.
First tried failed with swingarm. Yesterday painted light casings and few small bits - worked much better. Really need to be careful not to create runs. Layer will be thin, but I have 2 layers under, so it should be just fine. I like finish I am getting though. Will do few more practice batches with smaller parts before tackling actual frame.
Katit's 1978 KZ650 project 03 Jun 2022 09:46 #868143
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1865
I’ve had good success with VHT roll bar and chassis paint. Several very light coats.
Last edit: by Mikaw.
Katit's 1978 KZ650 project 03 Jun 2022 10:33 #868149
  • katit
Yes, I like finish and I learned about coats. Instruction says 2 light and one medium coat within hour, like 10 minutes inbetween. Spray pattern somewhat narrow, have to keep can pretty far away, at least in my experience.
Also, Where I sanded with 320 in some places I do see sand marks, this VHT goes very thin. Need to do better job prepping. But results looking good so far.
As soon as I try to put nice wet coat - I get runs. Light coats may not look good when you apply them, but look OK when dry.
Last edit: by katit.
Katit's 1978 KZ650 project 03 Jun 2022 10:56 #868152
  • Mikaw
  • Mikaw's Avatar
VHT caliper paint will cover minor imperfections. It flows out well. Again you need to watch coat thickness, it will run faster than a ding dong dasher!
The following user(s) said Thank You: katit
Katit's 1978 KZ650 project 13 Jun 2022 17:22 #868734
  • katit
Frame still not painted (duh). Had to re-sand to remove orange peel. Waiting for better weather (100+ here now)
Question, do I need those bead locks? New rims don't have holes for them and I was just wondering if they really needed..
Katit's 1978 KZ650 project 14 Jun 2022 07:48 #868770
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 266
I raced flat track in my past and had tire pressure as low as 12 PSI and never used bead locks. I would ditch 'em.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
Katit's 1978 KZ650 project 14 Jun 2022 07:52 #868772
  • katit
Thanks! I don't plan to race it, thats what I figured, as long as I ride normally with stock power and good pressure - there is no reason.
Did some work(no pictures, sorry). Rear wheel is done. New rim, spoked, new bearings installed.
Re-thinking "instruments". I might just keep originals and send them for restoration. I figured it might be more than buying electronics, but probably save a lot of time figuring mounting and and keep it original at the same time.
Katit's 1978 KZ650 project 26 Jun 2022 17:26 #869400
  • katit
Progress. Finally frame painted and to my liking. Maybe. Maybe not 100% perfect but 8/10 on my scale and once assembled will be just perfect.
Katit's 1978 KZ650 project 26 Jun 2022 17:27 #869402
  • katit
More assembly. Ready to go. Some new parts, some cleaned, some painted.
Katit's 1978 KZ650 project 26 Jun 2022 17:32 #869403
  • katit
Front wheel is ready to put on a bike (even though to make it a roller for now). Rear wheel spoked and trued. Need to mount a tire and will be ready.
I am moving forward getting roller going so I can install engine and refocus on what else is next.
Katit's 1978 KZ650 project 26 Jun 2022 17:39 #869404
  • Mikaw
  • Mikaw's Avatar
Looking gooood!
Katit's 1978 KZ650 project 26 Jun 2022 22:54 #869408
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1816
Definitely coming along
