- Thank you received: 675
1977 KZ1000 Restomod
- DoctoRot
Other considerations down the road for the ZRX forks is a fork brace, and have the forks tuned. I found the stock valving and springs to be kinda harsh on mine. I recently had them reworked by Matt Wiley at Racetech with new springs, compression gold valve, and HFR rebound valve and it rides sooooo much better. Way less skittish during WOT, and much better road holding in general.
- calum
- Thank you received: 401
Skidmark wrote: My take would be to have the face of them pointing directly at your face while in the rider position, to avoid any glare while riding. Having them parallel to the upper triple could allow reflection to prevent you from reading them.
You mean I'm supposed to look at the gauges when riding :whistle:
Good call though, I'll angle them up a bit. Probably something that I wouldn't have noticed until the first ride :pinch:
Current Project:
www.kzrider.com/forum/11-projects/616901...-spare-parts-project
1977 KZ1000 Restomod ( www.kzrider.com/forum/11-projects/614517-1977-kz1000-restomod )
2000 BMW F650GS
- Thank you received: 1918
Only after you see the red and blue flashing lights....:woohoo:
- calum
DoctoRot wrote: Don't forget the stock kz triple has about 1.25" of drop .
Thanks, I took the drop into account. With stock setup the top of the forks end up being about 4mm above the lock nut under the top yoke (4mm at 26°). The offset is about 60mm. With my setup the forks sit about 30mm above the lock nut and they have about 33mm offset. The forks are about 7mm shorter than stock as well.
Got new linear springs on the way. Wasn't sure on the brace, would have definitely put one on stock shocks. Will look into it again and have a look at the valve options over here.
Current Project:
2000 BMW F650GS
- calum
I though that was when you were supposed to completely ignore them
![;) ;)](/media/kunena/emoticons/11.png)
Current Project:
2000 BMW F650GS
- katit
- Thank you received: 49
Red is shifting light. What is blue one? Time for nitro?
- calum
![:) :)](/media/kunena/emoticons/8.png)
Current Project:
2000 BMW F650GS
- 750 R1
- Thank you received: 394
Thanks
- calum
Here are the brackets I have (got them a lot cheaper):
www.lsl.eu/143lt?___store=en&___from_store=de
And here are the ones we're putting on the boys Zephyr (same length):
www.kickstartershop.de/en/2-cnc-aluminiu...ets-43mm?language=en
EDIT: Just saw you're down in Oz. Might be hard to get down there - The way things are I won't be back for a while either... Could maybe send some down if the dimensions fit.
Current Project:
2000 BMW F650GS
- 750 R1
- calum
If yours end up being too short and mine too long I can send the "v" part down to my sister in Townsville the next time I put something in the post - then it's just national postage rates. No indicator mounts on mine though.
Current Project:
2000 BMW F650GS
- 750 R1
Thanks again.....!!
