1977 KZ1000 Restomod 22 Feb 2022 05:32 #862737
  • calum
  • calum's Avatar Topic Author
  • Thank you received: 394
Not a bad idea, but then I'd need to find some way to fix it to the engine. I think I'll just shift it to the back of the plexiglas next to the control box - almost directly under the seat bracket. I'll move the RFID antenna forward a bit. Should have plenty of room then.
1977 KZ1000 Restomod 01 Mar 2022 11:30 #863043
  • calum
Got back to the electrics today. Recovering from our favourite virus at the moment so just doing a bit at a time.
Put a couple of motogadget relays in and made a new bracket for the relay wich will be mounted somewhere... still not sure where. The easiest option is shown in the picture below, but I'm not sure about electrical interference with the main unit. Looked at mounting the relay down by the starter as suggested by Jim, plenty of room but I'm not sure about the heat. Also thought of putting it behind the battery, means longer wires but may be OK.
Last edit: by calum.
1977 KZ1000 Restomod 01 Mar 2022 21:23 #863057
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Best of health to you, Calum
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
1977 KZ1000 Restomod 02 Mar 2022 06:42 #863068
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
Speedy recovery and no long term effects!
1977 KZ1000 Restomod 03 Mar 2022 09:30 #863117
  • calum
Thanks guys. It seems to be letting up. Managed to get the battery box done today.
1977 KZ1000 Restomod 03 Mar 2022 12:02 #863126
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1920
A thin rubber or foam layer would protect the battery case cracked by the screw heads.
1977 KZ1000 Restomod 03 Mar 2022 13:09 #863133
  • calum
There's a layer of rubber around the battery. Just can't glue it in until everything has been painted/powder coated. I'll also be sinking the heads of the screws until they're flush - that's tomorrows job :)
1977 KZ1000 Restomod 03 Mar 2022 15:18 #863140
  • 750 R1
  • 750 R1's Avatar
Interested to see what you think of the ultrabatt battery, I'm considering using one on my bike, due to the light weight and freeing up space under the seat...
1977 KZ1000 Restomod 03 Mar 2022 16:16 #863145
  • calum
I'm hoping it works out OK - not much room for anything else!
1977 KZ1000 Restomod 03 Mar 2022 22:35 #863157
  • 750 R1
  • 750 R1's Avatar
I'm in the same boat, if I want to use everything I have so far, i really need a smaller , lighter battery...   They are supposed to be good, I've spoken to the Aussie distributor about them, he's a friend of a friend...
1977 KZ1000 Restomod 04 Mar 2022 07:29 #863170
  • Skidmark
  • Skidmark's Avatar
I just picked up this Antigravity AG-801 battery.  About the size of a carburetor and only weighs 1.5 lbs.  The lithium ion batteries require a special charger and cannot be jumped using a conventional lead acid battery, though.  The charger was around $35, so no big deal.
Retired gearhead
'81 KZ-750 E2
The following user(s) said Thank You: Bozo
1977 KZ1000 Restomod 04 Mar 2022 08:03 #863174
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 518
Looks like a nice product but they aren't doing a great job of selling it on their site.  Not a lot of details, no manual or detailed specs, and the support page says:
Support function is not working yet.
Please contact us…
This photo is the only piece of information on the entire site:
www.ultrabatt.com/ultrabatt/wp-content/u..._Flyer_2014_EN-2.jpg
My dad's '74 Z1
'00 ZRX1100
Last edit: by DOHC.
