1977 KZ1000 Restomod 03 Jan 2022 08:14 #859969
  • calum
  • calum's Avatar Topic Author
  • Thank you received: 394
Good thing - there almost certainly aren't enough church windows in Ireland ;)
1977 KZ1000 Restomod 03 Jan 2022 08:51 #859973
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
  • Thank you received: 250
HA yeaa we have a love of the church windows over here, i  actually have something, that i will defiantly will not be using, what are you leaning to on the seat? i have a Zephyr1100 seat cover, brand new, was goin to use it for a project but changed my mind on it, yours if it is any good to you.
Last edit: by kzstreetfighter71.
1977 KZ1000 Restomod 03 Jan 2022 08:55 #859974
  • calum
I won't really know what I need until the seat pan is done, but the seat will definitely be a lot shorter than the 1100 - will be a single seater. , don't want anybody on the back of this one.
Will almost certainly have to get the seat cover made, but thanks anyway.
1977 KZ1000 Restomod 11 Jan 2022 10:15 #860408
  • calum
Frame is off getting welded for the last time...
The camera decided to focus on the wall :(
Last edit: by calum.
1977 KZ1000 Restomod 16 Jan 2022 09:55 #860594
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
My 77 been waiting over 10 years to finish it.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1977 KZ1000 Restomod 16 Jan 2022 10:01 #860596
  • calum
Time to get back to work!
1977 KZ1000 Restomod 20 Jan 2022 09:49 #860785
  • calum
Got the frame back.
 Did the back end myself - changed the brackets to a straight bar and just plugged the end of the tubes. Welds are a little bit better with the reading glasses.
1977 KZ1000 Restomod 20 Jan 2022 11:37 #860789
  • Wookie58
  • Wookie58's Avatar
  • Online
  • Moderator
  • Thank you received: 1916
Looking good Calum
1977 KZ1000 Restomod 20 Jan 2022 11:53 #860790
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Being able to clearly see the weld puddle, and the seam, makes a remarkable difference in weld quality.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
1977 KZ1000 Restomod 20 Jan 2022 14:11 #860797
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
Got the frame back.
Just curious, have you installed the swing arm, the rim and tire you are going to use along with the shocks without their springs and check to make sure nothing will come in contact with your tire throughout the whole range of suspension travel??
1986 RG500G 2 stroke terror.
1977 KZ1000 Restomod 20 Jan 2022 17:40 #860805
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1928
The rear end upswept frame looks like to have a lot of space left for the suspention travel and tire/fender clearance.
1977 KZ1000 Restomod 20 Jan 2022 22:35 #860809
  • calum
I haven't taken the springs out but the clearance under the tail section would allow the springs to fully compress. I'll double check again later though, thanks.
