Mrs. slayer's GPz1100 refresh & upgrade 18 Jul 2022 10:06 #870555
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
  • Thank you received: 178
Sorry, the ride did not go as intended.  I know you will get it sorted!
50 tooth?!!!  Wow!  Are you running 17 or larger counter?
The following user(s) said Thank You: gpzer
Mrs. slayer's GPz1100 refresh & upgrade 20 Jul 2022 08:09 #870710
  • slayer61
  • slayer61's Avatar Topic Author
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 266
Yes Sir. I'll get after it this coming weekend. The front sprocket is an 18 off the top of my head. This size combo gives the same ratio AND physical size of the OEM 630 chain set.
She hasn't ridden since the last flag hand off down to Fresno, and as HER bike was working, she took advantage of the day and rode around the block and down town just a little bit. It was good to see her back on a bike again.
Be safe brother.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
Mrs. slayer's GPz1100 refresh & upgrade 25 Jul 2022 08:21 #870984
  • slayer61
So the maiden voyage of Mrs. slayer's newly refreshed '81 GPz1100 was a success on most every front! After stripping the bike down to the frame I left a few details to be wrapped up:
1). The left side mirror wasn't snugged down properly
2). The shifter lever was a little too low
3). The throttle return spring on the flat slides is too stiff
Ya know? After a complete revamp stem to stern, touching everything except the bottom end of the engine... I'm pretty happy with it. Items 1 & 2 can be solved easily!
Be safe everybody & enjoy riding season!
The following user(s) said Thank You: Forrest
Mrs. slayer's GPz1100 refresh & upgrade 25 Jul 2022 11:09 #870999
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
That is AWESOME!  Glad to see you and Mrs. Slayer out on the vintage bikes.  You did a great job to have such a short list of adjustments to make.  Quite an accomplishment!  Kudos to you!
Mrs. slayer's GPz1100 refresh & upgrade 25 Jul 2022 13:53 #871021
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Agreed^^  it turned out awesome! Easiest way i have found to negate the heavier pull of the RS carbs is a smaller diameter pulley on the throttle sleeve. the sacrifice is a longer pull to WOT.
Last edit: by DoctoRot.
Mrs. slayer's GPz1100 refresh & upgrade 25 Jul 2022 14:32 #871025
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
Nice matching Simpson Helmets BTW!
