KZ750H Restoration 12 Apr 2020 14:02 #823174
  • calum
  • calum's Avatar Topic Author
  • Thank you received: 390
So, just repaired the wiring on the fuel sensor - all good.
Thanks again loudhvx, if you hadn't told me what was going on I probably wouldn't have waited long enough for the light to go on.
KZ750H Restoration 12 Apr 2020 14:34 #823184
  • calum
All ready and waiting for me to finish painting the tank...
EDIT: looks like the vacuum pipe fitting is on the wrong side (according to the parts diagrams - it was on the same side as in my photo when I got the bike), something to do tomorrow I guess.
Last edit: by calum.
KZ750H Restoration 12 Apr 2020 16:31 #823190
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Your petcock came out a lot nicer than mine did, I still have to work on cleaning my low fuel switch a bit better, but now I know how to test it!
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
KZ750H Restoration 12 Apr 2020 16:50 #823191
  • calum
Mine were in a *lot* better condition when I started out :)
By the way, the original o-rings for the tap are so much better than the one in the rebuild kit. Really smooth and easy to turn - let's just hope nothing leaks!
KZ750H Restoration 13 Apr 2020 20:03 #823282
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
calum wrote: Cockpit done :)
setting standards for a resto right there. nice work.
Last edit: by DoctoRot.
KZ750H Restoration 13 Apr 2020 20:29 #823284
  • Thank you received: 2829
Looks better than new!!! Very nice!!! Ed
KZ750H Restoration 14 Apr 2020 05:01 #823306
  • calum
Thanks guys :)
Just went to put the new OEM base gasket on (11060-1348). It just disintegrated trying to get it over the four corner studs. It was really tight and although I tried to put even pressure on from all sides it just split. Before I threw it in the trash I bent it in a few places and it seemed really brittle.
Is this normal? I'm thinking I'll cut the tabs off the corner holes on the next one, don't want to risk waiting even longer to get the engine back together.
KZ750H Restoration 15 Apr 2020 23:12 #823466
  • DoctoRot
  • DoctoRot's Avatar
thats the problem with buying NOS gaskets. I have had similar experiences. they should be semi-pliable if you are going to use them, brittle gaskets fail. not all NOS gaskets are brittle but if its 40 years old....
KZ750H Restoration 19 Apr 2020 17:41 #823695
  • calum
Thanks Vic, I went for the metal gasket second time around (11060-1726). Think I'll stick with them in the future, the surfaces are pretty good on the crankcase and block so shouldn't have any leaks (fingers crossed).
Got the top end back together today (replaced the stud that was too long). Had a choice of head gaskets as I got all three pretty cheap. Went with the oldest one as I will definitely be pulling the head next winter. Will try the MLS one next year.
Got some stickers on ebay for the brake callipers. Look pretty decent (need to do some dusting though).
Finally got the new coil brackets painted as well. Will put them on tomorrow and get the exhaust back on as well.
KZ750H Restoration 20 Apr 2020 11:45 #823736
  • calum
Got the coils and exhaust back on. I guess it's time to get to work on the tank :)
KZ750H Restoration 20 Apr 2020 12:39 #823742
  • Skidmark
  • Skidmark's Avatar
Nice... I hope your tank is in better shape than mine!
Retired gearhead
'81 KZ-750 E2
KZ750H Restoration 20 Apr 2020 13:41 #823754
  • calum
Thanks. There's a bit of surface rust as I was a bit careless putting it in storage (should have sprayed some wd-40 in there). Should only need a quick soak though. The major is getting the dents sorted.
Some of the old filler even survived the sandblastng. I just filled it again last summer, primed it and have let the new bog settle. Now I just need to do a bit of touch up work.
