Saving a '81 KZ750-E 20 Dec 2019 13:34 #815669
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
Skidmark wrote: You do really nice safety wiring, btw...
I had to have certain nuts and bolts safety wired when I was road racing.
I still safety wire most of the critical nuts and bolts on my streetbikes.
The actual wiring is the easy part. Its drilling all those little holes in all those nuts and bolts that is a real pain in the a$$!!!!!
1986 RG500G 2 stroke terror.
Saving a '81 KZ750-E 20 Dec 2019 13:49 #815671
  • DoctoRot
  • DoctoRot's Avatar
I have been safety wiring a lot of nuts and bolts on my GSXR 7/12 project. dunno how may 1/16" drill bits I have gone through, but... a lot. the worst is having the bit snap in the fastener and spending 15 min trying to get the broken bit out.
If you're looking for a new rear master cylinder Brembo makes super nice rear masters for like $50-60 but needs a push rod and reservoir for another $20. I put one on my kz1000 with a lightweight brembo rear caliper.
Last edit: by DoctoRot.
Saving a '81 KZ750-E 20 Dec 2019 13:59 #815672
  • Dr. Gamma
In my old age, I just don't have the temperament anymore to stand there and drill all them little holes!!!!
Considering how cheap titanium fasteners have gotten in the past years, and my lack of temperament in my old age. I just been ordering most of the fasteners I need in Titanium with all the holes for safety wire already drilled in them!!!!!
Last edit: by Dr. Gamma.
Saving a '81 KZ750-E 20 Dec 2019 14:15 #815673
  • Skidmark
  • Skidmark's Avatar Topic Author
  • Thank you received: 260
Sounds like an argument for off the shelf rear sets! B)
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Saving a '81 KZ750-E 20 Dec 2019 15:13 #815675
  • Skidmark
The corrosion doesn't look good in the piston bore. I have to admit I wasn't prepared for
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Dec 2019 15:16 #815676
  • Skidmark
The loud bang when the piston finally came loose!
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Dec 2019 15:40 #815677
  • Skidmark
The caliper and piston will soak for a while in the parts dip. It may be just old brake fluid. I'll do a close inspection once the parts are clean.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 20 Dec 2019 15:42 #815678
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2678
Corrosion in the caliper bore doesn't matter. It does in the master bore and on the caliper piston surfaces though because they are the contact surfaces for the seals.
Last edit: by Nessism.
Saving a '81 KZ750-E 22 Dec 2019 10:49 #815750
  • Skidmark
The piston looks pretty good after cleaning it up. The top has some chips in it, but I think that won't be an issue.
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 22 Dec 2019 13:17 #815760
  • Skidmark
Almost done cleaning and blasting the rear caliper parts. Finished blasting the triple clamps and float bowls, too (since I was using the blast cabinet).
Retired gearhead
'81 KZ-750 E2
Saving a '81 KZ750-E 22 Dec 2019 16:45 #815762
  • Nessism
  • Nessism's Avatar
  • Away
No eBay APP ID and/or Cert ID defined in Kunena configurationIn case you need brake pads these are about as good as they come...
Saving a '81 KZ750-E 31 Dec 2019 13:27 #816197
  • Skidmark
More refinishing. I am using heat paint on the brake components. I also finished blasting and painting to carb tops. The outer chromed ones were really pitted, so those will go on the inner carbs. The smooth, nicer looking ones will be on the outer carbs.
Retired gearhead
'81 KZ-750 E2
