My 20-year owned KZ650 09 Sep 2018 17:45 #790622
  • tseohs
  • tseohs's Avatar Topic Author
  • Thank you received: 0
Hi,
Here's my 650 that I've had for about 20 years. It's an ongoing project in the sense I'm always fixing or upgrading it. I bought it not running and got it going and now running like a beast with the help of this forum.
My goal has always been to upgrade it and increase performance while maintaining a pretty stock look. Luckily, when I got it, all the major parts were there. The tank, wheels, and seat were in really good shape.
The stock look has been leaned with the help of low rise bars, short signals, a cropped front fender and rear fender delete, some frame trimming including the rear peg perches, and a custom chain guard. Rear fender is replaced with an zx-11 taillight and plate mount.
Suspension is an upgraded but fairly stock front with progressives in the rear. Drive train is all new sprockets, seals, chain, and hardware.
Brakes are rebuilt stock with stainless lines, modern master, and polished calipers.
Ignition is all dyna with slightly overgapped stock NGKs and copper wires. It also has the coil relay to provide better spark.
Carbs are rebuilt stock with uni pods and more fuel to accommodate the increased airflow. I think it's running 2 sizes up on both pilot and main jets with the needle on the third setting.
Pretty much everything else has been rebuilt or upgraded as well through the years.
Most importantly, it starts instantly, doesn't stumble or backfire, and once warmed up, it rips. It's pretty amazing how much pep these motors have and how much power they make even at high rpm. It runs a tad bit lean at high speeds but only when it is windy and getting a bunch of air turbulence but otherwise about as good as it gets. I'm thinking of building an airbox to replace the pods.
The delkevic pipe is a nice piece of craftsmanship and fits and sounds great. I made a custom stainless steel hanger since the bike has no rear peg perch. I ran the pipe without the baffle a few times which was fun but not good for the hearing.
I'll post some more detailed photos soon.
My 20-year owned KZ650 09 Sep 2018 17:54 #790623
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
It's a great looking bike. Still looking for my KZ650...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
My 20-year owned KZ650 10 Sep 2018 15:49 #790685
  • baldy110
  • baldy110's Avatar
  • Thank you received: 510
Nice looking bike, clean and simple.
My 20-year owned KZ650 11 Sep 2018 22:33 #790738
  • azman857
  • azman857's Avatar
  • Thank you received: 111
I've read on the 650.info forum where kz 750 heads with the larger valves and bigger carbs. Up to 29mm cabs. GPz cams was the hottest set up.
My 20-year owned KZ650 21 Oct 2018 09:08 #792636
  • waktaylor
  • waktaylor's Avatar
  • Thank you received: 9
What year is this bike
My 20-year owned KZ650 21 Oct 2018 18:09 #792663
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Looks like '78 or '79 to me, but I can't say for sure. The motor is later than '77.
My 20-year owned KZ650 21 Oct 2018 19:26 #792666
  • Thank you received: 2829
Judging by the foot peg mounts (1 hole in each mount) it is a 1978. Ed
My 20-year owned KZ650 22 Oct 2018 18:01 #792698
  • rstnick
  • rstnick's Avatar
  • Thank you received: 374
Your 650 looks very nice.
I'm sure your well attached to her.
Others here, and myself included, have also owned a KZ for many years and would not like to be without one.
Great bikes.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
My 20-year owned KZ650 01 Dec 2018 09:06 #794440
  • tseohs
Hi guys,
VIN says it's a78. When I got it, it had a non-recirculating valve cover which I can't remember if was stock for 78. It also came with a spare motor that has the re-breather valve cover.
My 20-year owned KZ650 02 Dec 2018 18:15 #794519
  • tseohs
My 20-year owned KZ650 02 Dec 2018 18:22 #794521
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
PURDY :evil:
My 20-year owned KZ650 16 Dec 2018 11:27 #795229
  • rstnick
  • rstnick's Avatar
Yes your bike looks very nice.
Frame is a '78, and the motor would not have the head with emissions crap.
The '79 models got the emission stuff.
Brake rotor looks 1979 or later.
That's when holes started appearing in the rotors.
Do you know what the tail light came off of?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
