Saving a 1980 750 twin. 29 Jul 2019 13:01 #808365
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
I would put an oil cooler on the "To-Do-List" first. Bronze bushing the connecting rod for the wrist pin is a must have mod for tuned engines.
High Performance engines had and extra oil line (Jet) that spayed oil to the bottom of the piston and wrist pin for cooling and lubrication.
Last edit: by Scirocco.
Saving a 1980 750 twin. 29 Jul 2019 13:34 #808366
  • DoctoRot
  • DoctoRot's Avatar Topic Author
  • Thank you received: 664
Hmmm, I wonder if it would be possible to make that happen
Saving a 1980 750 twin. 29 Jul 2019 14:12 #808368
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
This is for the cam chain in my daughter's car. It sprays in two directions.
Last edit: by SWest. Reason: sp
Saving a 1980 750 twin. 29 Jul 2019 16:47 #808378
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
Heavier cross hatching ?
78 KZ1000 A2A
Saving a 1980 750 twin. 30 Jul 2019 09:41 #808429
  • DoctoRot
Some people smarter than I are thinking there may have been detonation. I found a video of the sound it was making. Thoughts? it was only coming from the right side and from the valve cover.
Last edit: by DoctoRot.
Saving a 1980 750 twin. 30 Jul 2019 14:19 #808438
  • bluej58
  • bluej58's Avatar
78 KZ1000 A2A
Last edit: by bluej58.
Saving a 1980 750 twin. 16 Nov 2019 23:44 #814079
  • DoctoRot
getting a move on this. I decided to bite the bullet and get some custom JE pistons in 86mm bore. this will put the bike at 906cc. If you would like to get in on a limited run of pistons and sleeves let me know soon as I will be pulling the trigger on this in the near future.
Attachment IMG_0820.JPG not found
Saving a 1980 750 twin. 21 Feb 2020 22:51 #819671
  • DoctoRot
Think I found the source of the noise... unfortunately this went south so fast it damaged the crank as well
Saving a 1980 750 twin. 22 Feb 2020 04:10 #819678
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
Go back to the post you made on Nov. 11 2018. Looks like the crank had issues from the start.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Saving a 1980 750 twin. 22 Feb 2020 08:40 #819689
  • DoctoRot
You think that black stuff was a symptom? I checked the crank for all the things listed in the manual and sent it out to be professionally checked. what else can I do?
Saving a 1980 750 twin. 22 Feb 2020 18:33 #819708
  • Nebr_Rex
  • Nebr_Rex's Avatar
Looks to me that one rod journal and the center main journal had been hot before assembly.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Last edit: by Nebr_Rex.
Saving a 1980 750 twin. 23 Feb 2020 02:03 #819720
  • DoctoRot
Hmmm that rod journal does look like it got hot. The main bearings all looked OK this time out. it was the opposite rod journal that got burnt up bad this time but both were shot. I’m thinking oil startvation. Gonna check out the oil pump closer. Any other suggestions for the next build?
