Saving a 1980 750 twin. 27 Jul 2017 06:06 #767805
  • 80B4
  • 80B4's Avatar
  • Thank you received: 105
Nice work on that top mount Vic!
1980B4 1000
1978 Z1R
1978 B3 750
Saving a 1980 750 twin. 29 Jul 2017 15:57 #767945
  • DoctoRot
  • DoctoRot's Avatar Topic Author
  • Thank you received: 664
I got the ignition system installed and I was dying to hear this thing run, so I hot wired it. This motor has great compression and is very difficult to turn over with the kick-starter even with my 230lbs behind it, but it still started up first kick!
Saving a 1980 750 twin. 29 Jul 2017 16:13 #767948
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
Good job, sounds great. :woohoo:
Saving a 1980 750 twin. 31 Jul 2017 07:16 #768024
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
sounds damn good.
Saving a 1980 750 twin. 08 Jan 2018 13:50 #777075
  • DoctoRot
I decided to scrap the custom foot-pegs I was working on and modify the stock brackets to use Tarozzi pegs, I also turned some aluminum spacers so they are solid mounted now. all that remains is wiring, fuel plumbing, and a license plate holder. gettin close!
Last edit: by DoctoRot.
Saving a 1980 750 twin. 08 Jan 2018 17:33 #777087
  • SWest
  • SWest's Avatar
  • 10 22 2014
FOXY :evil:
Saving a 1980 750 twin. 09 Jan 2018 02:02 #777095
  • DoctoRot
forgot to some add these pics of the new shifter. I went a little overboard on the speed holes with the stock shifter so I re-made it out of thin wall steel tube, and TIG brazed the fittings on. It threads into an aluminum Tarozzi splined clamp.
Saving a 1980 750 twin. 19 Mar 2018 13:13 #780459
  • DoctoRot
I'd like to get some opinions here as I have compromised the strength of a semi-structural screw and I don't want my own "genius" to kill me. I drilled and tapped this head-stock screw to mount an oil light. The difference between the OD minor thread diameter and the ID major thread diameter is about 4mm so I am left with 2mm thick walls. This screw appears to pretty lightly loaded as the steering stem fits into the top triple and is firmly clamped with a pinch bolt. I torqued the modified screw to the factory value of 36ft/lbs and it seems fine. I have also seen aluminum aftermarket replacement screws available for this application so I can't imagine that this is super critical strength wise. thoughts?
Saving a 1980 750 twin. 19 Mar 2018 15:37 #780469
  • Wozza
  • Wozza's Avatar
  • Thank you received: 30
My thought is the bolt is used to make sure the the top clamp is fully pulled down onto the stem before being locked into place by the pinch bolt,
I cant see how it would cause any catastrophic failure
1982 KZ550H1
Last edit: by Wozza.
Saving a 1980 750 twin. 19 Mar 2018 18:20 #780482
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1900
A M16 screw can torque up to 240 Nm at 8.8 grade fine pitch.
You are on the save side.
Saving a 1980 750 twin. 21 Mar 2018 01:15 #780550
  • DoctoRot
blasted and painted with Gun Kote. i tested it and it is really bright.
Saving a 1980 750 twin. 21 Mar 2018 10:15 #780565
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
Too cool.
