first time trying bondo/custom emblems
  • 77KZ650
  • 77KZ650's Avatar Topic Author
22 Nov 2006 14:29
#94103
I picked up a can of bondo(body filler) at canadain tire today to work on my side covers. step 3 of the instructions says to add so much "cream hardender" to a certain amount of the filler.... the only thing in the can is the filler, do I have to buy the hardener seperatly or is it supposed to come with the filler or do I even need it? :blink:
thx
Scott
edit: Upon closer inspection of the can, I found this: NET WT 1 Lb 14 OZ FILLER 1.0 OZ HARDENER
is this stuff premixed?
Post edited by: 77KZ650, at: 2006/11/22 17:33
Post edited by: 77KZ650, at: 2006/11/29 22:15
07 MDP Rookie of the Year
  • Pterosaur
  • Pterosaur's Avatar
  • Visitor
Re: first time trying bondo
22 Nov 2006 14:39
#94107
Nope. Not pre-mixed. ;)
Should be a little squeeze tube of red or blue or maybe even green goo that came along with it - usually under a pop-top plastic lid on the can.
If not, CT prolly has extra on the shelf, a little tube for not more than $2 CDN, I'd hope.
A little dab 'll do ya. Per ounce of bondo, a 3 gram squirt will be enough. The setting time of the bondo/hardener mix will vary depending on the amount of hardener goo used.
One tube of hardener goo should easily handle more than one can of bondo.
  • 77KZ650
22 Nov 2006 14:47
#94109
thx PT, theres definatly room for a tube under the plastic cover(theres a regular paint can type cover under that) looks like Ill be heading back up to ct again... not that I mind going to the place, I could browse through the stuff every day. I went there to get a $9 can of bondo and some sandpaper, and along with a few other things I "had" to pick up after I saw them, I ended up spending over $75:laugh:
  • Pterosaur
  • Visitor
22 Nov 2006 15:07
#94115
You betcha. Toy stores for older boys. :laugh:
Hey, while you're there, might wanna take a gander for a pack of *bondo spreaders* - little spatula-looking things without handles. Usually yellow. Come in a graduated-size assortment, usually 3 per. From the sounds of it, you'll only need the smaller.
That is, unless you want to do it all with your fingers. :P
Better limber up my typing pinkies, I smell a weekend's worth of questions coming my way... :cheer:
  • wireman
  • wireman's Avatar
  • Visitor
22 Nov 2006 19:08
#94170
and under no circumstances go to relieve yourself with any left over bondo on your hands,dont ask how i know this! :S :blush: :huh: :dry: :blink: :blink: :blink: :unsure: :ohmy: :sick: :woohoo: :silly: :woohoo: :silly: :P
  • Pterosaur
  • Visitor
22 Nov 2006 19:19
#94176
Tech answer:
Look (or feel) familiar? :blink: :woohoo:
(hint: Bondo curing is an exothermic reaction) ;)
  • kawtoy
  • kawtoy's Avatar
22 Nov 2006 19:20
#94177
Do not use too much hardner. The bondo will start to dry too fast as you spread it around. Pieces will start to peel off and it will get hard to work with. As a reference a dab of bondo about the diameter of a soda can mixed with hardner the diameter of a dime should be about right.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • wireman
  • wireman's Avatar
  • Visitor
22 Nov 2006 19:40
#94182
Pterosaur wrote:
Tech answer:
yeah thats the one!:blink: :S :pinch: :woohoo: :silly: :woohoo: :silly: :P
  • 77KZ650
22 Nov 2006 20:53
#94193
yikes, thx for the tips guys
  • mariozappa
  • mariozappa's Avatar
23 Nov 2006 04:49
#94253
When looking for the 'bondo spreaders'. Try to get the same color of the hardener, pink or yellow.
That color of the spreader is the right mix for the bondo. Too light, and it won't harden well or take longer. Too dark and it will harden up faster than you can imagine!
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • wiredgeorge
  • wiredgeorge's Avatar
24 Nov 2006 12:33
#94569
I have to ask... why are you using Bondo on plastic side covers? It is intended for use on steel surfaces... like your gas tank. As far as the "spreader color" goes, I can't imagine the color helping since when you mix Bondo filler with hardener, it is a dark reddish brown and when it cures it gets almost light pink. What fix are you attempting on the sidecovers?
Post edited by: wiredgeorge, at: 2006/11/24 15:35
  • Pterosaur
  • Visitor
24 Nov 2006 12:50
#94572
Because it works.
It works really, really well. It adheres well, it flexes well, it has similar thermal expansion properties, it loves being primed and painted over, it's easy to work with - and it's cheap.
I've been doing it for over 30 years, and knew a whole generation of body-people that did it before me.
No need to take my word for it - but it'll do nicely. ;)
As far as the "spreader color" goes, I can't imagine the color helping since when you mix Bondo filler with hardener....
That one has me hanging too. I've probaly spread a TON of bondo over the years, and that's the first I've heard of it... :huh:
