Gas tank mod before repaint
  • Clifftex
  • Clifftex's Avatar Topic Author
20 Sep 2006 07:54
#78140
I am about to modify my KZ650 gas tank. I need to cut into it. Is there a solution I can put into it so that the sparks from the cut wheel don't cause the tank to explode in my face?
  • andoman
  • andoman's Avatar
Re: Gas tank mod before repaint
20 Sep 2006 08:47
#78151
Yea, its called air. Empty the tank as best you can. Get a fitting on the end of your air hose that leaks a little bit. (Tape the button or trigger down slightly. You don't need much, just a little bit). Stick it way down into the tank and let a litle air piss into it for at least 12 hours. Preferably 24. Make sure you are in a well ventilated area! Move your hose end once to get into both sides. 99.9% of the fuel will be gone. It wont even hardly smell like gas.
This sounds like a lot of work, but if you have rust in your tank, especially rusty seams in the nether raches, fuel can be trapped and cause a serious explosion risk. Moving air through the tank will get it all.
As for your tank mod: Whats up? Need to hold more fuel? Can you enlighten the group with some pix?
Good luck!
  • wireman
  • wireman's Avatar
20 Sep 2006 10:28
#78185
take it to a radiator shop and have it boiled out.;)
  • flht1997
  • flht1997's Avatar
20 Sep 2006 10:39
#78193
fill it with inert gas, CO or argon or a miix from a wire welder works pretty good. i always seem to get a little "poot" every time i weld or cut a tank.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • Nevco48
  • Nevco48's Avatar
20 Sep 2006 11:00
#78206
Nothing wrong with gettin' a little poot now and again...
  • Clifftex
20 Sep 2006 13:35
#78266
Thanks so much for the tips - most helpful. As to the reason for the mod, I hope you fellows don't disapprove too much, but I am turning it into an electric. I have modified the frame to accomodate 4 batteries and will be using the gas tank as a repository for the electrical components (sans batteries and motor). If you are interested, I have been documenting in photos what I have been doing. When I get it done, I'd be honored to share some of them with you. Thanks again.
  • wireman
  • wireman's Avatar
20 Sep 2006 14:34
#78281
pictures,pictures!just tell them it had 3 rods knocking and non origional paint,and most importantly put this in BIG LETTERS no Z1s or Kz 900-1000s were hurt in the production of this bike and youll be reasonably safe! :P
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
20 Sep 2006 15:19
#78293
wireman wrote:
...just tell them it had 3 rods knocking and non origional paint...
Rods knocking is no excuse. You must repair! Non-original paint though... well, that's punishable by death.
:lol:
Seriously, I'd love to see some progress pics, maybe even some "before" pics to get us going...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • mykznme
  • mykznme's Avatar
20 Sep 2006 16:40
#78311
step#1. place mouth over filler.
step#2. long deap breathes:blink:
R.I.P. Odd Ivar
  • Clifftex
20 Sep 2006 17:50
#78330
Ouch!! Well, I guess I deserve that. My next one will be a restore. Just for the record, this one had a siezed engine, transmission questionable, and in need of a complete rewire. Thanks again guys.
  • wireman
  • wireman's Avatar
20 Sep 2006 21:55
#78379
most importantly though NO Z1S OR KZ900-1000S were harmed in the making of this project! :P
  • btchalice
  • btchalice's Avatar
21 Sep 2006 19:21
#78616
if your leaving it open just fill it with water and paint the inside when your done . and we definitely want pics
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
