Seat Build w/pics
08 Aug 2006 13:28 #68076 by ronjones
Replied by ronjones on topic Seat Build w/pics
Good idea, kawtoy.
09 Aug 2006 15:02 #68341 by ronjones
Replied by ronjones on topic Seat Build w/pics Update
I've done a bit more work on the seat. I got some material from the craft store. It's not really artificial leather. It's more like some of the material you would see on a high quality weather suit. A bit streachy and looks pretty durable. The "teeth" that hold it on, the seat pan, don't cause any tearing. This is kind of a second approximation, as it still needs a lot of work, but other than some smoothing, and a bit more shapeing, I can't do much more until I get the bike running and see how it feels and what alterations it needs. The "sissy bar" is just setting there, I wanted to see how it would look.
Post edited by: ronjones, at: 2006/08/09 18:03
09 Aug 2006 15:08 #68343 by ronjones
put the wrong photo, here's the right one
09 Aug 2006 15:09 #68344 by ronjones
a closer shot,
09 Aug 2006 15:11 #68346 by ronjones
passanger seat looks a bit lumpy
09 Aug 2006 15:12 #68349 by ronjones
needs more shaping
09 Aug 2006 15:14 #68351 by ronjones
need to use the grinder to smooth foam, can see uneven under cover.
Comments and suggestions are welcome
09 Aug 2006 16:39 #68360 by odl666
Replied by odl666 on topic Seat Build w/pics Update
get a nice thin piece of foam maybe like an qurter inch thick and just glue it to the top. But forst off whne doing this you should always cut the top layer off and svae it so you can re glue it later. good luck
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
09 Aug 2006 17:12 #68368 by ronjones
I've been thinking of doing this, maybe w/memory foam. I may not have to cut too much off the top, because I think I'm going to have to build it back up a little. Now I hafta find a piece of 1/4 in memory foam, that's not 9 ft. long. (standard length at foam store)
Thanks for the thought.
14 Aug 2006 14:47 #69389 by kzmarvo
Replied by kzmarvo on topic Seat Build w/pics Update
Looks like your seat is about to give birth!:P
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
14 Aug 2006 16:41 #69417 by ronjones
:lol: :P :blush: :S
14 Aug 2006 18:51 #69469 by EddieBoy
Replied by EddieBoy on topic Seat Build w/pics Update
i use water proof...odor eaters blue carpet padding..works very good for the top layer...it has a thin vinyl coating on the padding...
and i like the xtra protection for those beer and pickled egg nites:)
