Seat Build w/pics
  • ronjones
  • ronjones's Avatar Topic Author
Seat Build w/pics
06 Aug 2006 10:29
#67487
Since I can't do any michanical work, because I'm waiting for parts, I thought I'd do a little work on making a seat. This is what I've been able to accomplish in a couple of hours w/an electric knife. A good rule of thumb w/working w/foam is that it's better to work w/thicker foam because you can always take some off. The lighter foam is much less dense than the black foam and I expect it to crush down, severly, when I get a cover on it.
  • ronjones
Re: Seat Build w/pics
06 Aug 2006 10:30
#67488
early carving
  • ronjones
06 Aug 2006 10:30
#67489
more carving
  • ronjones
06 Aug 2006 10:31
#67490
more carving
  • ronjones
06 Aug 2006 10:33
#67492
shaping continues
  • ronjones
06 Aug 2006 10:34
#67493
still shaping
  • ronjones
06 Aug 2006 10:34
#67494
1st approximation on bike
  • kawtoy
  • kawtoy's Avatar
07 Aug 2006 06:35
#67716
Why the big hump on the back? I know the road racers use it so they have something to brace against but why on a street bike? Do you have an angle grinder? With a cutting wheel attached it will work great to smooth out the seat. Much better and easier than trying to smooth it out with a knife. I just got done cutting down a seat for a customers GS450. I cut the big pieces off with a hacksaw and the spent about 5 min smoothing it out with the grinder.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • ronjones
07 Aug 2006 07:09
#67726
The "big hump" on the back will not be a big hump when I cover it. The light colored foam is much less dense than the black foam, so I'm making it big now so that when I put the cover on it, it will compress into something that should be comfortable for a passenger. I'm using various foam that has come in packageing for some very delicate instruments, some is very dense and some not so much. I'm also trying to make it so that it gives me some lower back support, on longer rides, when I lean back. I don't have a grinder but I do have one of those "spiral saws" that has a 90 degree attachment for putting sanding/grinding disks on. Any idea what size grit I should get? Any other advice/ideas are very welcome.
Thanks for the reply
  • Werewolfx
  • Werewolfx's Avatar
08 Aug 2006 11:51
#68047
I don't believe it matters what grade you use.
Chris
  • ronjones
08 Aug 2006 12:10
#68052
Maybe one of the grinding heads I have will work. Thanks
  • kawtoy
  • kawtoy's Avatar
08 Aug 2006 12:15
#68055
I doubt that the grit size matters. It will be rotating so fast that anything will work. Try it on some left over foam first.
