Gas leak, from the side logo...
  • heartless
  • heartless's Avatar
Re: Gas leak, from the side logo...
04 Aug 2006 04:54
#67065
just make sure you give whatever you use plenty of time to cure - COMPLETELY - before you go putting gas back in. if the directions say 24 hours - then you better leave it for 24 hours - if it says 24-36 hrs - best to leave it the 36...
good luck!
  • pumps
  • pumps's Avatar
05 Aug 2006 15:26
#67341
only fill it half way.
And lean away from that side. Alot.:woohoo:
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • Robjb84
  • Robjb84's Avatar Topic Author
06 Aug 2006 14:49
#67538
Hey I went ahead and bought the Seal All as you suggested reborn, since you did the exact same dumb thing as I did ;)
I sanded down a small area of paint around the screw hole then coated the logo screw in the seal all, screwed it in, then put a layer of seal all around the screw. I'll let it dry for the rest of the day, though it does mention only 6 hours is needed, I'll be patient this time :)
I might add another layer in 6 hours on top of the first layer, just to be safe. Not going to look pretty but at this point im desperate not to have a leaking gas tank :P
At the end of the day, a slightly nasty looking left side of my tank is better than how it looked before with 75% of the paint stripped off :o
Post edited by: Robjb84, at: 2006/08/06 18:10
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
06 Aug 2006 15:01
#67540
This is the stuff You want.
Trust Me...it works!
I'never used it on a bike tank,but I have used it on gas tanks...amazing stuff!
SEAL ALL
1977 KZ1000 A-1
  • Torch
  • Torch's Avatar
06 Aug 2006 22:25
#67658
Just flush the tank extremely well to remove any possible fumes and weld the sucker up. I think the tank looks better without the emblem anyway. MIG and a grinder will fix you up in no time.
  • Robjb84
07 Aug 2006 11:21
#67784
Well, the Seal All is holding up so far. I put 2 coats of seal all over the screw i pout back in, let it dry overnight and today i filled the tank up. No leakage at all :D
  • mykznme
  • mykznme's Avatar
07 Aug 2006 19:43
#67912
being a painter, if you brought me that tank and asked me to paint it i would turn it down.
even if it looked kosher from where it sits.
if i sanded it smooth and found crap like that i would return the tank asap and tell you to keep your money.
free of charge even:angry:
again, being a painter i cant stand to see slopp-assed
repairs. more to the fact if it makes more work for me.
if you care about your z then pay the money or invest in the tools to fix it right.
if you dont care enough sell it to someone who does:evil:
R.I.P. Odd Ivar
  • Robjb84
08 Aug 2006 06:10
#67972
Oh I have no intention of painting the tank, if anything I will sand down my spare tank, line that and get that painted. This one was just a big improvement on what I had before.
There is no way I can afford to do a proper fix for this, too much other crap I need to deal with on the bike that is going to cost me. Im not leaking gas anymore so I consider that a win :D
  • mykznme
  • mykznme's Avatar
08 Aug 2006 21:36
#68176
sorry rob if i offended but i have a few pet peaves.
if you got it going and its a temp solution then i can understand. my p.o.v. is from one side of the spectrum.
i get probably 3-4 "do-it-yourself" repairs a year and it drives me nuts.
my post last night was hindered by my encounters with a few "wild turkeys" and a p.o.ed wife. (my appologies:unsure: )
R.I.P. Odd Ivar
  • Robjb84
09 Aug 2006 06:50
#68240
lol its cool man, I understand where you are coming from. Believe me, I would like this bike to be perfect but this 550 dollah cycle is turning into a 1000 dollah cycle with all of the nickle and dime stuff :P
