trying to remove gas tank liner
  • chopper1963
  • chopper1963's Avatar
Re: trying to remove gas tank liner
07 Jun 2026 19:02
#924682
How much is a clean, straight tank on FB Marketplace?!!?
  • asphalt900
  • asphalt900's Avatar
08 Jun 2026 02:10
#924690
Ditto that, find a suitable replacement. You have to know sometimes person's "coat" these tanks for a reason that go far beyond just covering flash rust. If somehow you do find a way to remove the existing coating it might turn out to be a pin cushion of holes in the metal? Sometimes we just have to pick our battles..
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Jun 2026 02:30
#924691
Totally agree that it's normally done for a reason, I only lined mine because of the amount of "fab" work I had done on the tank (HD filler and 22mm petcock mount), there was always the chance that a "pin hole" in a weld somewhere would have allowed fumes to "pickle" the paint
