Fuel Tank Clean
  • Vintage3
  • Vintage3's Avatar Topic Author
Re: Fuel Tank Clean
10 Jun 2025 15:05 - 10 Jun 2025 15:08
#913596
Thanks.  I think I'll get a telescopic mirror as suggested and take a better look.  Does electrolysis leave the zinc coating intact?
I have read that phosphoric acid mixed with water to a specified % is a good option as it leaves a zinc coating for better protection where Evapo Rust removes it.
Last edit: 10 Jun 2025 15:08 by Vintage3.
  • Nessism
  • Nessism's Avatar
Re: Fuel Tank Clean
10 Jun 2025 17:10
#913597
Both will eat off the zinc.  Not to worry, though, because the tank has no zinc.  It's just the petcock, sending unit, cap, things like that, which should be removed regardless.
  • Vintage3
Re: Fuel Tank Clean
10 Jun 2025 19:58 - 10 Jun 2025 20:00
#913598
Thanks. I've been reading lots of other posts on this Nessism by you. Great info. The paint on this tank is beautiful and if I do this I don't want to f it up. The phosphoric acid seems like the most effective option  but for my situation I get the sense Evapo Rust will be safer as it should not harm the paint. If there is no zinc coating to worry about as you say
, is there any draw back with Evapo Rust on the short or long term ie will it be rust free for just as long with proper care?
Last edit: 10 Jun 2025 20:00 by Vintage3.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Fuel Tank Clean
11 Jun 2025 04:58
#913604
... All needed is a battery charger, some soap powder. water (hot.warm works faster) and a piece of steel. ..
Hello Gd4now,
Which sort of soap powder are you referring to?
Thanks
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Nessism
  • Nessism's Avatar
Re: Fuel Tank Clean
11 Jun 2025 05:56
#913605
Hello Gd4now,
Thanks
Bill
Washing soda is commonly used for electrolysis.
The following user(s) said Thank You: gd4now
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Fuel Tank Clean
11 Jun 2025 07:12
#913609
It is sometimes called washing soda, it just needs to have sodium carbonate in it. Keep in mind this is not the fastest way to remove rust from inside the tank but it does work well.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • ckahleer
  • ckahleer's Avatar
Re: Fuel Tank Clean
11 Jun 2025 07:27
#913611
An inexpensive option is vinegar. It will not work on heavy rust, but on light surface rust, it works fine.
97 ZL600
94 VF750c
94 KE100
82 KZ305
The following user(s) said Thank You: Nessism, Gdizard
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
Re: Fuel Tank Clean
11 Jun 2025 08:34
#913613
We have done many tanks with EvapoRust. Once it's done go straight to a rinse with diesel which also coats the tank to prevent flash rust. Pour in about a gallon and shake. Pour the diesel into a gallon milk jug and watch the sludge settle. Pour the diesel back in and dump the sludge. On rusty tanks sometimes I make a mop with a rag and attached to a length of coat hanger so I can bend to wipe excess sludge from the corners. Repeat several times until satisfied. The diesel coating won't hurt a thing when you fill up with gas.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: Nessism, Vintage3, sf4t7, 78kawltd, Gdizard, Wookie58
  • TexasKZ
  • TexasKZ's Avatar
Re: Fuel Tank Clean
11 Jun 2025 18:17
#913631
This works very well on sludge, dried crud and very light rust.
www.kwick.biz/how-to-flush-your-fuel-tank/
  • Vintage3
Re: Fuel Tank Clean
12 Jun 2025 04:39
#913647
Thanks. When you say go straight to diesel for a rinse, to confirm then you are bypassing a  rinse with water per the Evaporust instructions?
  • Kelly E
  • Kelly E's Avatar
Re: Fuel Tank Clean
12 Jun 2025 19:46
#913672
Yes I bypass the water rinse. The last thing I want to do is put water in a freshly derusted tank.
1983 Honda CB 1100F
And more
The following user(s) said Thank You: Vintage3, Gdizard
  • AOB85
  • AOB85's Avatar
Re: Fuel Tank Clean
27 Aug 2025 10:58
#916453
I have a Zephyr 750 tank that is worse than yours sitting with 5 gallons of Evapo-Rust in it, going on day 5 now.  I plan to rinse it out with some kerosene I have sitting around.  Evapo-Rust leaves a sticky film if you don't rinse it.
