Chrome dress up kit for engine finns.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Chrome dress up kit for engine finns.
25 Feb 2022 14:36
#862923
Actually I thought about them a long time ago, but gave up when I could not determine how they fastened to the head.
Still don't know, so my opinion is askew.
1982 KZ1100-A2
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
25 Feb 2022 15:14
#862931
Man! Have I been out of the loop!  I guess life gets in the way. It is sure grand to communicate with such peaple. Remdemer when you could go to local bikeshop, pub. or hooligen and discuss such things, with out too much bs?
Original poster seems OK  and  as a longtime member  of our forum he is aware of members speaking their minds.
And NO  flagrant attacks have taken place to scar anyone.
So lets not  turn this into  something its not........
Peace to all...
Real problems  like invasions and war  are reasons to  fight ,, Not  KZ accessories
The following user(s) said Thank You: slmjim+Z1BEBE, SWest, Mikaw, Scirocco, M1zore, krazee1
  • Wheelhop
  • Wheelhop's Avatar
26 Feb 2022 07:54
#862944
I too would be concerned about these things blocking the air flow to cool the engine.
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • 750 R1
  • 750 R1's Avatar
26 Feb 2022 20:45
#862960
I've seen this mentioned a couple of times so I'll ad my 2 cents worth.  I think they'd add to the surface area of the block and probably draw heat , therefore they would actually help remove heat by increasing surface area and acting like a heat sink, being further out in the breeze it would lose that heat faster , possibly aiding cooling. I just can't see them "blocking" air flow at all as most airflow comes from the front.  It could possibly act like bigger fins on the block...
  • Wheelhop
  • Wheelhop's Avatar
27 Feb 2022 06:11
#862966
excellent point.
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • Mikaw
  • Mikaw's Avatar
27 Feb 2022 07:18
#862968
They attach to the upper case at two of the clutch cover and the inner points housing bolts, and have two tabs the rest on one of the block fins on the top. Attaching point surface area is so small I don’t see how they could conduct heat transfer. They are slightly spaced away from the block so I’d think air flow restriction would minimal. I can’t see them affecting convection in either way. They are a period correct aftermarket item, if you like them good, if not good also. It a personal choice thing.
  • ronnieV
  • ronnieV's Avatar
27 Feb 2022 11:24
#862973
Well said!!
  • 750 R1
  • 750 R1's Avatar
27 Feb 2022 13:48
#862983
From what I gather, some of them attach to the head bolts, they would heat up and probably draw away a little heat, even if its only a small amount. My point was that I doubt they'd trap heat....
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
27 Feb 2022 15:01 - 27 Feb 2022 15:01
#862989
Kinda like what some Japanese riders do with steel clamps.
Last edit: 27 Feb 2022 15:01 by kzstreetfighter71.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
27 Feb 2022 16:31
#862991
They try to enlarge the cooling surface and heat transfer to the air.
  • Shankkole
  • Shankkole's Avatar
28 Feb 2022 05:04
#863001
I cannot help but LOVE the steel clamp look!
Cheap effective and ugly pretty all at once.
The following user(s) said Thank You: ghostdive
  • Wheelhop
  • Wheelhop's Avatar
04 Mar 2022 20:02
#863215
there is a set on ebay now item # 154881283045  for  $299
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
