Kz1100 Fuel tank leak from side
- F64
- 81-KZ440D2
Re: Kz1100 Fuel tank leak from side
11 Jul 2020 13:52
Chris,
Depending on how many coats of clear you put on the tank, you could color sand the clear to mirror flatness.
But you need to have enough thickness in the clear.
It pretty easy just be patient with the process.
I've posted this before, but I'll post it again as it shows the process done by hand.
If you know the process, you can make a $100 paint job look much more expensive.
It's just very labor intensive.
81-KZ440-D2.
LIC, NY
LIC, NY
- chrisM
20 Apr 2021 09:33
New New Update: I never did find a solution to this long term. Every filler and patch that I tried, ended up peeling off (yes, even after following the instructions exactly.)
The gas tank holes are just too big, I think. They are not really pin holes.
I've sanded this down and replaced the patch 4 times now. Enough.
I am looking for a replacement tank now:-./
- PaintWorkz
21 Apr 2021 20:06
YES ....finding another tank would be the best way to go, that model should be reasonably priced compared to a Z1
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
- Rimm
22 Apr 2021 20:52
Русский язык.<br />Может кому пригодится. Для KZ 1100 очень хорошо подходит бак от Yamaha xjr400.
Обратите внимание на кран, на баке XJR он расположен идеально.<br />
The following user(s) said Thank You: chrisM
23 Apr 2021 11:38
Hello and welcome
Rimm
Your Cyrillic text is not readable here in the western hemisphere , sorry.
Member gazzz is located in the Ukraine and can help you with your tank leak problem.
Send him a PM
kzrider.com/forum/11-projects/610746-kz650-cafe-racer?start=0
kzrider.com/forum/profile/51887-gazzz
www.gazzz-garage.com/
Send him a PM
- chrisM
27 Apr 2021 11:56
It seems Yamaha xjr400 tank is a good fit. Looks pretty rad too. I will start looking for one. Thank you!
I have some friends who helped me with the translation:
Спасибо большое!!! Пришлось ли вам делать какие-то регулировки чтобы укрепить бак к раме? Я начну искать прямо сейчас! Украина выглядит забавным местом для катания!
- Rimm
28 Apr 2021 19:47Thank you.
I was born and live in the north of Russia.
Unfortunately, there is practically no information on the Russian-language Internet resources dedicated to the Kawasaki Z, KZ, GPZ series. I am very glad that I found kzrider.com.
I beg your pardon, my knowledge of the English language is scarce.
To install the Yamaha XJR400 fuel tank, you will need to weld 2 pieces of 25mm pipe to the frame.
The original tank attachment protrusions do not need to be removed.
Rubber damper 35-38 мм.
Weld the stud. Which makes it possible to fix the fuel tank in the hole near the seat.
Unfortunately, I have no idea how the XJR fuel tank will pair with the original KAWASAKI seat.
With respect, Roman.
