Disc brake bolts corrosion protection
- gordone
30 Jan 2020 06:51
Is it possible to todo something with the disc brake bolts to avoid corrosion?
Send them to a company who can do something with them with acid or something?
Project:
Project:
Re: Disc brake bolts corrosion protection
30 Jan 2020 07:00 - 31 Jan 2020 05:37
Do you mean the disk/rotor bolts? They probably need to be re-plated with zinc or something.
There are plating kits, but you could send them to a plating company.
Mine were showing some corrosion, so I got good used rotor bolts from a ZX10 or ZX11. I forget which one.
Many Kawasakis used the same size bolts.
Last edit: 31 Jan 2020 05:37 by martin_csr.
30 Jan 2020 07:22 - 30 Jan 2020 07:26
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationMaybe just replace them with new old stock ones. Find the correct part number and then check eBay by doing a search using that part number. Here's a couple examples, but I'm not positive yours uses the same part number. The part number for the 1977 KZ650-C1 is 92007-032. Ed
REPRODUCTION BOLTS:
REPRODUCTION BOLTS:
Last edit: 30 Jan 2020 07:26 by 650ed.
30 Jan 2020 07:33 - 30 Jan 2020 07:33
No eBay APP ID and/or Cert ID defined in Kunena configurationHis rotor bolts are probably the same as most of the 80s models with dual disk &/or cast alloy wheels.
BOLT,SOCKET,8X30
92001-1951
BOLT,SOCKET,8X30
92001-1951
Last edit: 30 Jan 2020 07:33 by martin_csr.
The following user(s) said Thank You: 650ed, gordone
- gordone
30 Jan 2020 09:10
These are identical to what I have, but maybe its less expensive delivery my bolt in instad of bying all new, approx 10 per disc ? 30 total?
I found a company in Norway now, ask for price so I can compare.
martin_csr wrote: His rotor bolts are probably the same as most of the 80s models with dual disk &/or cast alloy wheels.
BOLT,SOCKET,8X30
92001-1951
Project:
Project:
30 Jan 2020 10:09 - 30 Jan 2020 11:57
Probably 7 per disk & 21 total for the front & rear. I bought a good used set of disk/rotor bolts on EB. fairly cheap.
Many Kawasaki models used the same bolts & there are probably other 8x30 rotor bolts with a different part number that are the same.
For more results, instead of searching by part number, search each model on EB or EB.UK.
ZX10. ZX11. ZX1100. ZX6. ZX7. Ninja ZX600. ZR750. etc. etc.
Last edit: 30 Jan 2020 11:57 by martin_csr.
- gordone
30 Jan 2020 15:58 - 30 Jan 2020 15:59
www.partzilla.com/product/kawasaki/92001...2dedc1cc9eb162495db3
So these bolts shall have protection from corossion orginal?
My problem is the bolt has got old?
Project:
Project:
Last edit: 30 Jan 2020 15:59 by gordone.
30 Jan 2020 16:09 - 30 Jan 2020 16:14
ACF -50
www.learchem.com/products/acf-50.html
It is not great at removing rust, but it is amazing at preventing it. Some guys hose down their entire bike with it. Electronics, painted surfaces, polished surfaces, et cetera. Don't get it on the brakes, and probably not the seat or tires.
Last edit: 30 Jan 2020 16:14 by TexasKZ.
31 Jan 2020 05:34 - 31 Jan 2020 05:35
750-4 projects with zinc plating for the bolts. or send your bolts to a company. or get new bolts. or get good used.
Retroactive KZ750E Project by Nessism >> page 2
KZ750H Ltd Restoration by calum
scroll down for the zinc plating. just past the seat.
Last edit: 31 Jan 2020 05:35 by martin_csr.
- gordone
03 Feb 2020 06:25
No eBay APP ID and/or Cert ID defined in Kunena configurationWill these fit?
Project:
Project:
03 Feb 2020 06:51 - 03 Feb 2020 07:00
I would say yes. guessing. The ZRX bolts are square or flat where the threads end near the bolt head. The KZ bolts are tapered there.
From the diagrams at Partzilla for the 2001 ZRX1200R (ZR1200-A1).
BOLT,SOCKET,8X30
92150-1771
Fit >> many modern Kawasaki models from 1997-on.
Partzilla - Socket Bolt 8X30 - 92150-1771
From the diagrams at Partzilla for the 1983 KZ750-L3.
BOLT,SOCKET,8X30
92001-1951
Fit >> KZ550/KZ650/KZ750/ZX600/ZX750/ZG1000/etc
Partzilla - Socket Bolt 8X30 - 92001-1951
note: Partzilla may be substituting the 92150-1771 bolts in place of the 92001-1951 bolts. Kawasaki may list 92150-1771 as a superseded part number, to be used in place of the earlier part number. Kawasaki dealers should have supersession info not available in the diagrams.
BOLT,SOCKET,8X30
92150-1771
BOLT,SOCKET,8X30
92001-1951
Last edit: 03 Feb 2020 07:00 by martin_csr.
- gordone
03 Feb 2020 10:05 - 03 Feb 2020 10:06
Have asked partzilla what alloy the bolts they selling is.
I hope the bolt has a alloy for corrosion.
Project:
Project:
Last edit: 03 Feb 2020 10:06 by gordone.
