Does Bondo retain water (from sanding/wet sanding etc)
- Gdailey2112
- 82 KZ1100D1
07 Jul 2019 05:05
Wondered if bondo could retain water and later come through paint? Thanks
1982 KZ1100D1
- Warren3200gt
Re: Does Bondo retain water (from sanding/wet sanding etc)
07 Jul 2019 09:31 - 07 Jul 2019 14:58
Nope. Just make sure its dry from wet sanding before priming.
Last edit: 07 Jul 2019 14:58 by Warren3200gt.
07 Jul 2019 14:32
Bondo leaves a rough texture. You have to sand it smooth, coat it, sand until the color doesn't have orange peal or pits in it. Do a test coat in that area before moving on.
- PaintWorkz
08 Jul 2019 18:04
No reason to wet sand Bondo. It does take a long time to dry if it gets wet, I think the water soaks in. I used to use metal conditioner on tanks before first coats of epoxy primer......ran into blistering a couple years later. Switched to self -etching primer to eliminated getting Bondo wet.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
