Condition inside the gas tank
  • gordone
  • gordone's Avatar Topic Author
Re: Condition inside the gas tank
21 Feb 2019 05:16
#798985
Nessism wrote: Looks good. Maybe that spot is not corrosion? Chunk of varnish? Can you reach into the tank with a bent rod or something and try scraping at it?
Will try doing it, with the spot.
What about the corrosion left between the plate in the botton in front, mostly on one side? Just leave it?
When its come to corrision is the main problem particals in the gas and then coming into the carbs and you get problem or is it whole in the gas tank ?
Project:
  • KZB2 650
  • KZB2 650's Avatar
21 Feb 2019 07:22
#798986
Wow that looks way better............. I Bought a Golan fuel filter that goes down to 10 microns and flows like crazy ..... should stop anything that comes loose. (most of the lower cost ones go to 40 to 70 microns) Not cheap 50 bucks (but is cleanable) ....... when I drained the gas this fall it was one of the first times I saw no pieces of anything coming out of the bowls.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • gordone
21 Feb 2019 07:45 - 21 Feb 2019 07:47
#798987
Yes, much better :)
What about corrosion and whole in the tank? Should I try to take the small piences rest of corrosion?
Maybe just take a need session in some years?
I din’t thing it will be any issue now? Have inlet filter in the tank and outside.
I want to have the tank for many years, maximize the life of the bike...
Here is a picture from the first time cleaning it with acid when I got the bike 2-3 years ago.
Project:
Last edit: 21 Feb 2019 07:47 by gordone.
  • gordone
21 Feb 2019 11:45 - 21 Feb 2019 11:47
#798992
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • TexasKZ
  • TexasKZ's Avatar
21 Feb 2019 13:33
#799008
I bought the mini filter, but if I could do it over, I would get the super mini.
www.golanproducts.com/filters.html
  • KZB2 650
  • KZB2 650's Avatar
21 Feb 2019 15:10
#799017
Yep Texas got the super mini w/ 5/16 barbs I think off Amazon but may have been Ebay ....... of course check around for the best price Gordone if you decide.
1978 KZ650 b-2
21 Feb 2019 15:50 - 21 Feb 2019 15:51
#799020
I've been using the Golan Super Mini Fuel Filter ( SKU 1222522 70-312G 5/16" Barbed Fittings) for 6 years and it works great. It can easily be opened to clean it if needed. I also use the Goodyear 5/16" Fuel Hose SAE 30R7 Part # 65123, and it also works great. DO NOT buy the Gates Barricade Fuel Hose - the inside of it curls up when you install it and causes a problem. I use a stainless 5/16" elbow to make things fit neatly (see below). I bought it at a place that sells beverage equipment. I also use spring clips rather than the screw type (see below) because they make life easy compared to the screw type. Ed
Last edit: 21 Feb 2019 15:51 by 650ed.
The following user(s) said Thank You: KZB2 650, gordone
  • old_kaw
  • old_kaw's Avatar
22 Feb 2019 08:57 - 22 Feb 2019 09:00
#799056
gordone wrote: Yes, much better :)
You may want to cut down on the caustic chemicals there Gordone. There are other things out there that will remove the iron oxide without eating the metals in the process. That filler neck is so eaten up that it looks like it is two fill-ups away from crumbling into the tank.
But HEY! All I can do is suggest and tell what I have used successfully on numerous tanks.
1981 Kawasaki Kz1000K1
Last edit: 22 Feb 2019 09:00 by old_kaw. Reason: hmmmmm
  • Nessism
  • Nessism's Avatar
23 Feb 2019 08:35
#799098
old_kaw wrote: You may want to cut down on the caustic chemicals there Gordone. There are other things out there that will remove the iron oxide without eating the metals in the process. That filler neck is so eaten up that it looks like it is two fill-ups away from crumbling into the tank.
Phosphoric acid is a great material to remove rust. You would have to leave it in the tank for weeks to cause any structural damage to good metal. If you were to leave it in for a long time the main thing you would notice is a white residue buildup on the metal which doesn't cause much of a problem anyway.
Oh, and Por-15 and Kreem sealing kits come with phosphoric acid to remove the rust. Not to mention, if you go to an industrial shop that does metal derusting, such as prior to painting, they always have a phosphate tank for that purpose.
Personally, stuff like Metal Rescue or Evaporust are good of course, but I don't use it unless the paint job on the tank is pristine and must be saved. Phosphoric acid won't hurt paint if you remove it quickly, but sometimes $hit happens when you aren't there to watch it.
  • old_kaw
  • old_kaw's Avatar
23 Feb 2019 09:04 - 23 Feb 2019 09:06
#799099
Por15 and Kreme use the acid as a metal etching agent, and as a rust remover. Once you have the metal etched and all iron oxide is dissolved, then keep using the same chemicals, it goes past etching and goes straight to the metal. Eventually, the metal is not being etched and iron oxide is not longer being removed, and the structural integrity of the piece is being remolded instead. Time to lay off the acids. :-)
To keep using the caustic acids because a little spot / spots are still showing only weakens the already cleaned up sections more. It also works it's way into the seams then trapped. Some may not get completely flushed out in the rinse. A radiator shop that does coatings professionally does not continually soak any parts time after time. If Gordone keeps using acid on this tank, it will soon develop leaks, most likely in the seams that look to be already there. I hope he is looking for a replacement, because it will soon be necessary.
*Note: the acid dips used to be an extreme drag racers thing to lighten up those 16 gauge steel car bodies to remove weight, when just skipping a few pastries would remove the same amount of weight.
Last edit: 23 Feb 2019 09:06 by old_kaw.
  • Nessism
  • Nessism's Avatar
23 Feb 2019 10:31
#799102
old_kaw wrote: Por15 and Kreme use the acid as a metal etching agent, and as a rust remover. Once you have the metal etched and all iron oxide is dissolved, then keep using the same chemicals, it goes past etching and goes straight to the metal. Eventually, the metal is not being etched and iron oxide is not longer being removed, and the structural integrity of the piece is being remolded instead. Time to lay off the acids. :-)
Phosphoric acid is generally quite mild (depends on concentration) and it will take soaking a long time before any serious metal damage will occur. It requires no neutralizing of the acid, just water rinse. I've used it on at least a dozen different tanks, some of which were seriously rusted, and only one time did I have any issues, and that was because there were already perforation holes through the metal.
I'm not passing judgement on Gordone. From what he's said the dwell period is not dangerously long so I see no reason to criticize him. After his first soak job it was clear that more time was needed. Beyond that, I'm not sure. I've soaked tanks for days at a time and the only thing that happened was white chalky buildup thereafter, which I removed with some aquarium rocks in the tank after that. His tank had not reached the same point so I think he's fine.
Oh, and a caustic chemical is a strong alkaline base. Acid is on the opposite side of the PH scale.
  • old_kaw
  • old_kaw's Avatar
23 Feb 2019 11:07 - 23 Feb 2019 11:08
#799105
Oh, and a caustic chemical is a strong alkaline base. Acid is on the opposite side of the PH scale.[/quote
I am not criticizing or passing judgement I think he's a good guy that wants to save an old kaw in a ferign country, so he's ok with me. :-) if I didn't actually care, I wouldn't take the time to offer my .02. I would just not read it at all, kinda like i did with the 650 idiot and his 15 posts per day on the same subject. it was clear that he just liked the attention from his constant trolling, slamming other people's bikes, then asking stupid questions in his puzzling guessing games -sometimes in the same posting.
Sorry to use the wrong terminology (caustic) to describe corrosive chemicals. It looks like that filler neck has had one too many dips in the Ph punch bowl. lol
Last edit: 23 Feb 2019 11:08 by old_kaw. Reason: proofreading is a good thing. :-)
