Painting a sidecover
- someonewakeuphicks
21 Oct 2016 12:45
Tried to do a search on this but my spotty internet on my phone isn't co-operating
The RH sidecover fell off while riding on the weekend
managed to score one from a local salvage place but it's Red and my bike is Silver.
What's the easiest way to remove/reattach the emblem and can anyone reccomend a rattle can that would match the original silver? Also do I have to prime and clear coat?
Many thanks
Many thanks
Always remember to keep the rubber side down!
Bikes
'78 KZ650c2 - Current love affair
'04 Fz6 - Current daily rider (until the KZ is finished)
'82 XJ550 Seca - RIP Little Red
Bikes
- jdvorchak
Re: Painting a sidecover
02 Nov 2016 21:25
Take your other side cover to a professional automotive paint store and see if they can use their equipment to custom match the color. The stores around here will also put it in a "rattle can" for you. Won't be cheap as going to Wal-Mart but it will be automotive grade paint and won't be that expensive.
Sand off old finish down to the base coat. No need to sand to the bare material.
Prime yes
Clear coat yes
Prime yes
Clear coat yes
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
- jdvorchak
02 Nov 2016 21:30
Sorry forgot about the emblem question.
No matter how it's held on, once the paint and clear coat have dried for a couple of days, you can re-attach with pro quality double sided tape.
If it has some posts and push nuts holding it on, carefully try to remove the "nuts" and lift off the emblem. If it's glued on you can apply heat from heat gun or hair dryer and take a piece of thin fishing line to get under the emblem and saw it off.
John
83 KZ550M1
83 KZ1100LTD
Also own:
John
83 KZ550M1
83 KZ1100LTD
Also own:
03 Nov 2016 04:58 - 03 Nov 2016 05:01
If the emblems have the push/lock washers, you can score/cut them with a dremel cutoff wheel, then pry them off ---- the old rusty fasteners should crumble. To reattach them I cut threads into the posts & used nylon lock washers plus a small dab of silicone caulk as a just in case (credit to skyman for the thread cutting idea).
Last edit: 03 Nov 2016 05:01 by martin_csr.
- diggerdanh
03 Nov 2016 05:31
Good idea about the thread cutting. I'll give that a try next time. I used small washers that fit tightly over the nubs along with a big dab of silicone.
03 Nov 2016 05:36 - 03 Nov 2016 09:35
Those stock-type push/lock washers are available at hardware stores, but I had a bear of a time prying off the old ones on the first try, so there's no way I'd ever use anything like them to reinstall the emblems. doh.
Last edit: 03 Nov 2016 09:35 by martin_csr.
- Kidkawie
- I bleed premix
03 Nov 2016 07:23 - 03 Nov 2016 07:24
+1 to cutting the original lock washers from the emblem post. Sometimes the post can break off trying to remove them.
If you can find a silver close to the current color, just repaint both side panels. Even if the color is a shade off it's not right next to the original paint like a car door/fender. Since the side panels are not prone to having gas/chemicals on them you can use off the shelf Duplicolor clear coat. For a more durable finish use a urethane clear like Spray Max.
Replace the side panel grommets and install a hitch pin through one of the mounting tabs so it wont hit the pavement again.
I used these small nuts to resecure my 900 emblems. DO NOT USE PAINT REMOVER on your side covers! Lightly sand the cover and feather out any damage.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 03 Nov 2016 07:24 by Kidkawie.
- Nerdy
03 Nov 2016 07:52someonewakeuphicks wrote: can anyone reccomend a rattle can that would match the original silver? Also do I have to prime and clear coat?
Have you looked on Amazon for the correct paint? If not, find the paint code and/or proper name and try a search. There are a couple vendors on there who sell the correct paint for my GPz (Firecracker Red) and a whole slew of Kawasaki racing green variants. I've never looked for silver but it's worth a shot.
It will be more expensive than an off-the-shelf rattle can but it will be correct.
And it seems like Krazy Glue would work to attach the emblems but I haven't tried that yet.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
03 Nov 2016 07:56
I had to go down to the plastic.
kzrider.com/forum/6-paint-a-bodywork/598...ur-tank?limitstart=0
