Cleaning inside of gauges?
- StreetfighterKz
01 Oct 2016 19:47
So after my 1000 decided to go swimming for a couple days earlier this year, my gauges have a bunch of silt and other crud on the faces behind the glass. I want to clean them but really don't want to completely disassemble them. I was thinking of dumping rubbing alcohol into them and trying to rinse them out that way.
Does anyone have suggestions?
Here's what they look like...
Thanks.
Later, Doug
Thanks.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- missionkz
Re: Cleaning inside of gauges?
01 Oct 2016 19:51
Lol.
If they are dirty like that from silty water submersion, you have more things to worry about then dirty glass!!
You'll need to peel the crimp rings off and completely disassemble them for proper cleaning.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- StreetfighterKz
Re: Re:Cleaning inside of gauges?
01 Oct 2016 19:59
I got the bike running and crankcases flushed. I'm in the process of cleaning and painting bits and pieces and this was a task on my to-do list.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
01 Oct 2016 20:07
02 Oct 2016 05:58 - 03 Oct 2016 04:58
Someone here on KZR used an automotive foaming spray cleaner. a product for the engine or wheels or something. or foaming glass cleaner. It was an old old topic, maybe by ambergrismoon or oldmanrock. or someone else. ???
The method might not be appropriate in this case. just throwing it out there...
Last edit: 03 Oct 2016 04:58 by martin_csr.
02 Oct 2016 16:26martin_csr wrote: Someone here on KZR used an automotive foaming spray cleaner. a product for the engine or wheels or something. or foaming glass cleaner. It was an old old topic, maybe by ambergrismoon or oldmanrock. or someone else. ???
I'd be really concerned about what the cleaner might do to the paint on the face of the gauge and on the needle. I'd also worry about all that extra moisture encouraging rust. I think disassembling and careful cleaning are called for in this case.
- StreetfighterKz
02 Oct 2016 17:03 - 02 Oct 2016 17:04
Thanks for the links and advice.
Ended up disassembling the tachometer today. Cleaned the insides, glass, face, etc. Also, sanded the outer case and masked off and sprayed it with some new gloss black paint as it was looking shabby anyways. Will take some assembled pics when the gauges are all back together.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 02 Oct 2016 17:04 by StreetfighterKz.
