81 spectre 1100 tank on 81 kz750
  • Kech65
  • Kech65's Avatar Topic Author
11 May 2016 09:23
#725729
Hi Everyone,
I'm just bought a 81 spectre 1100 tank and I've never tired to swap out a tank on a motorcycle but that being said but I was wondering if anyone here had tried something similar or if anyone had some tips on mounting and restoring the tank.
  • martin_csr
  • martin_csr's Avatar
Re: 81 spectre 1100 tank on 81 kz750
11 May 2016 14:16 - 13 May 2016 05:03
#725787
You'll figure it out soon enough, but from the diagrams at Partzilla the tanks mount differently at the rear.
The 750 has a bolt & hardware w a tank bracket, while the 1100 has a tab & rubber damper and it's probably bigger & longer than the 750 tank.
Last edit: 13 May 2016 05:03 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 May 2016 16:37
#725830
Pics?
  • Nessism
  • Nessism's Avatar
11 May 2016 17:12
#725837
swest wrote: Pics?
Steve, you should put that response in you signature line!
Post pics or go home. :lol:
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 May 2016 18:35
#725851
Can't help work on something you can't see. :unsure:
  • Kech65
12 May 2016 08:40
#725930
Sorry I'm still new to the forum, these are the pictures I have on hand
  • martin_csr
12 May 2016 09:10 - 12 May 2016 09:11
#725933
That's not a Spectre fuel tank. That type of fuel cap was found on the 70s models & some from the 1980 model year. A pic of the underside might be helpful.
Last edit: 12 May 2016 09:11 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 May 2016 10:00
#725941
Yes, of both.
  • Kech65
12 May 2016 10:32
#725952
I don't see the hinge to mount it on the kz750 on the back part of the tank. I think its going to need some more mods until it fits. Thanks for all the help fellas
  • Kech65
12 May 2016 11:47
#725973
here's the bottom of the tank
  • martin_csr
12 May 2016 11:55 - 13 May 2016 05:04
#725978
That's a 70s style tank, possibly from a KZ900 or 1000A fuel tank. The tab at the rear is for a fuel tank band to secure it.
Put it on your 750 spectre to check the fit.
Last edit: 13 May 2016 05:04 by martin_csr.
  • Kech65
12 May 2016 13:03
#725996
Thanks Boss
