Exhaust
- Willy1803
Exhaust
04 Feb 2016 16:41
Is it bad to have no baffles in it or should i get baffles for it its a 77 kz650 an right now i have washers as a baffle an it looks bad
Re: Exhaust
04 Feb 2016 16:51
Your stock KZ650 will not only sound better with baffles it will run better. You need an appropriate level of backpressure for the engine to develop full power at low to medium rpm. Ed
- Willy1803
Re: Exhaust
04 Feb 2016 17:17
Where would i get new baffles for it or how would i make new baffles
Re: Exhaust
04 Feb 2016 17:22
Do you know what exhaust system is on the bike? If not, maybe someone can identify if you can post a couple pictures. Ed
- Willy1803
Re: Exhaust
04 Feb 2016 18:06
Need a better side view.
- rrsmsw9999
Re: Exhaust
04 Feb 2016 18:59
The Delkevic 4-1 pipe sounds great, performs well and is stainless steel. And it quite affordable as far as pipes go. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Re: Exhaust
05 Feb 2016 02:45 - 05 Feb 2016 02:46
It's hard to see what you're dealing with from the tiny pics, but you might be able to plug the holes. or maybe weld on an end plate. ??? I was able to cut a couple of threads & install brass plugs from the hardware store. I think I used a high temp thread locker to keep them from vibrating loose.
Last edit: 05 Feb 2016 02:46 by martin_csr.
