kz1100 tanks
- cafebrat
kz1100 tanks
01 Feb 2016 04:54
Hey guys, ive tried posting on this topic before and got no feedback. Please help me out if you have any insight. Im looking to replace my stock tank with another shape that came on all the other 1100 models. Does anyone know if theses shapes will fit my frame?? I dont want to drop big bucks for a tank to find it doesnt fit. Below: my bike, bottom tank shape, tank i want to switch too, bottom of new tank
83 Kawasaki Kz1100 LTD
81 Honda cm400
72 Suzuki T500 Titan** 2-stroke
81 Honda cm400
- cafebrat
Re: kz1100 tanks
01 Feb 2016 05:00 - 01 Feb 2016 06:08
81 Honda cm400
81 Honda cm400
Last edit: 01 Feb 2016 06:08 by cafebrat.
- cafebrat
Re: kz1100 tanks
04 Feb 2016 10:21
Buehler? Cmon, i see people throwing turbos an superchargers on bikes here or building beautiful customs but nobody has swapped a different tank onto thier bike!?
81 Honda cm400
81 Honda cm400
- ramtough_63
Re: kz1100 tanks
04 Feb 2016 10:35
anything can be made to fit. there is nothing about those 2 tanks that lead me to believe they are a direct swap. take yours off turn it upside down and compare it with the tunnel on the one you want to purchase then compare length width etc... allot of altering goes into mounting points either on bice or on tanks to make the incorrect tank fit such as a simple rake in frame can change the mounting point on the correct tank so I am sure a different tank will take similar inganuity
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Mcdroid
- Gone Kwackers
Re: kz1100 tanks
04 Feb 2016 10:35 - 04 Feb 2016 10:38
I suspect that you haven't received any answers because no one has swapped out an 'LTD' style tank for a 1100 A model tank. One issue that you'll run into is that these 1000/1100 style tanks that are a bit more 'boxy/angular' e.g. 1100 Standard, early GPz1100, and ELR/SBR tanks, are longer than the smaller LTD style tanks...and long enough that the seat also has to be shortened or moved rearward when using this replacement tank. I do not have access to a 1100 A tank, as you pictured, but I do have standard 1000A series tanks, 1000B (LTD) series tanks, GPZ1100 tanks and GPZ750 tanks...but these won't answer your questions.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 04 Feb 2016 10:38 by Mcdroid.
- cafebrat
Re: kz1100 tanks
04 Feb 2016 12:45
Thanks for the replies guys. Hopefully it'll get the ball rolling. The hardest thing about it is that i don't have a model a tank i can measure and haven't been able to find dimensions of one. Based on the pictures of the bottom of the 1100A tanks, they look really close. And i would assume that the frame of the LTD and A, B C models isnt very different in the front except that the ltd has a longer subframe and swingarm. I got pictures of both undersides below:
81 Honda cm400
81 Honda cm400
- Rasp11
Re: kz1100 tanks
04 Feb 2016 13:41
That square tank is from a KZ1100A and should fit in the tank mounts on your bike, the only issue is how the seat fits with it.
Re: kz1100 tanks
04 Feb 2016 14:35
After looking at what you've already done to the bike I guess moving things around won't be a issue.
- cafebrat
Re: kz1100 tanks
14 Feb 2016 12:31
Thanks guys, im looking into finding an 1100a tank. The problem is finding one thats priced decently and in fairly good condition. Let me know if anyone has one for sale or sees on on ebay. Im looking to stay under $250
81 Honda cm400
81 Honda cm400
